Magnitude of Force within incline?
68 replies · 10K views
anglum
A block with mass of 5.5kg is held in equilibrium on a frcitionless incline of 34 degrees by the horizontal force F. The acceleration of gravity is 9.81m/s^2
What is the magnitude of F? answer in units of N
What is the magnitude of the normal force? answer in units of N
I converted 5.5 kg to 53.9N
then i used sin of 56 degrees * 53.9 to get the horizontal force of 44.68N
then i used cos of 56 degrees * 53.9 to get the normal force of 30.14N
however both answers were incorrect
because you need to use sin of 34 not 56 degrees. you have the basic concept of weight the the triangle it forms. but that triangle is proportional the incline, so they have the same angles.
ok but sin of 34 * 53.9 = 30.14N
and cos of 34 * 53.9 = 44.68N
so i get the same answers ... and they are wrong... that's why i am stuck
Yeah, use 34 degrees, not 56. Fh= Fg*(sin x)
Your angle of incline will be the angle you use in the computation.
so Fh= (54.0)*(sin 34) = 30.2 N
and Fn= (54.0)*(cos 34) = 44.8 N
Double check my work.. but I think that's how you do it..
Is there additional information in the problem you didn't include? Because I believe that's correct...
those answers are incorrect... that's why i am so lost
the drawing shows the incline... the slope of the incline is 34 degrees... the block on it is 5.5 kg which is 53.9N
it slopes up from left to right... there is a line horizontal that is labeled as F.. and above it is a arrow pointing down sayin 34 degrees as well... where this horizontal line F touches the block is in the top left corner of the block... then an angled line down off of the top left corner of the block slopes down the incline as well
i wish there was a way to draw out what they give u ... i tried to describe it the best i could
this is the best that i can describe the drawing shows the incline... the slope of the incline is 34 degrees... the block on it is 5.5 kg which is 53.9N
it slopes up from left to right... there is a line horizontal that is labeled as F.. and above it is a arrow pointing down sayin 34 degrees as well...where this horizontal line F touches the block is in the top left corner of the block... then an angled line down off of the top left corner of the block slopes down the incline as well
its an online class so when i enter the answer it tells me its wrong
did you round before the answer? maybe you need to round only after finding the answer. that can change it by .1 or .01 or whatever
i tried answers ranging from 30..05 to 30.2 and the same for 44.65 to 44.70
and they were wrong
Yeah, since its an online course where you enter the answer that might throw it off. Try my answers, I was careful with significant figures...
i am uploading the picture of the problem online.. i will have the link for u to see it in one minute
But I believe since the horizontal force touches the top left corner, and not the center of the block, it does not equal F parallel, so the formula does not apply... Let me give it another shot on paper...
Awesome, that would help a lot.
Ok, give me a minute I'll figure it out if someone doesn't before me.
thanks a lot i really appreciate it.. i thought for sure the sin and cos of the angle would solve this for me... but it didnt and left me puzzled
http://img234.imageshack.us/img234/1231/26425932hu7.jpg
the box is applying 53.9sin34deg along the surface to the lower left
now we have that new triangle
cos 34=53.9sin34/F, solve for F
thats problem number 1 i think
Yeah definitely. Well I know the formula won't give you the answer because it finds what that dotted line equals, and we want the solid line labeled F. So I"m tryin to figure out how to do that...
Yeah there you go, but its 54.0(sin 34), if you get picky. No?
when i solve for F for that i get 36.356N which is correct
now can i use that squared + X^2 = what squared to solve for number 2?
