Guineafowl
- 962
- 422
- TL;DR
- While working through the ARRL antenna book, I’d like to start putting some theory into practice.
Thanks to @berkeman for the ARRL book recommendation.
While trawling through the theory, I’d like to build an antenna to help cement theory with practice. The receiver is an old valve/tube radio, covering the SW band from 6-18 MHz, or 49-16m.
For simplicity, I thought a small, tuned loop antenna would be a good starting point. That is, one under 0.1 wavelength long, 0.085 suggested. (5-3 in ARRL book). So the design will be:
Transmission line: RG6 coax, directly into the radio’s banana sockets.
Antenna: centred on 12MHz, 25m wavelength, (x0.085=2.125m conductor length). Single loop, triangle. Conductor will be PVC-coated 2.5mm2 copper wire, although could be changed for, say, 3/8” copper pipe. As I understand it, a larger diameter conductor has a lower Q, and so a broader response.
There is an equation on page 5-5 to find the inductance of such a design. I assume I then calculate the inductive reactance at 12MHz, and spec a capacitor to suit, and place across the feed point.
I would also consider a physically smaller, multi-turn loop, essentially duplicating what’s already inside the radio, but at least understanding how it’s designed. It could also be placed away from interference.
As you can see, I’m at a very early stage, so any comments would be welcomed.
