Manipulating a Laurent Series Equation
The discussion revolves around manipulating a Laurent series equation to confirm its equality. Initially, the user struggled to manipulate the right-hand side to match the left, leading to confusion about convergence. After revisiting the problem and receiving guidance, they successfully demonstrated the equivalence of both sides. The conversation then shifted to expressing the function as a Laurent expansion, with suggestions to utilize Taylor series for simplification. Ultimately, the user gained clarity on the process and expressed gratitude for the assistance received.
cpburris
Show the following:
{\frac{1}{z^5\left(1-\frac{z^2}{3!}+\frac{z^4}{5!}-\frac{z^6}{7!}+...\right)}}={{\frac{1}{z^5}}+{\frac{1}{6z^3}}+{\frac{7}{360z}}+{\frac{31z}{15120}}+{\vartheta({z^3})}}
None
Not really a homework problem, just an equation from my textbook that I do not understand. I can't think of any way to even begin manipulating the right hand side to make it equal the left hand side.
Just to confirm equality (thanks to another user for suggestion), I multiplied both sides by of the equation by
##{z^5\left(1-\frac{z^2}{3!}+\frac{z^4}{5!}-\frac{z^6}{7!}+...\right)}##
to see if the right hand side equaled one. So,
##{z^5\left(1-\frac{z^2}{3!}+\frac{z^4}{5!}-\frac{z^6}{7!}+...\right)}\left({\frac{1}{z^5}}+{\frac{1}{6z^3}}+{\frac{7}{360z}}+{\frac{31z}{15120}}+{\vartheta({z^3})}\right)=\left({z^5}-\frac{z^7}{3!}+\frac{z^9}{5!}-\frac{z^{11}}{7!}+...\right)\left({\frac{1}{z^5}}+{\frac{1}{6z^3}}+{\frac{7}{360z}}+{\frac{31z}{15120}}+{\vartheta({z^3})}\right)##
##=1+\frac{z^2}{6}-\mbox{ no terms of order }z^2+...##
With no other terms of order ##z^2## it isn't clear to me that the series should converge to one.
Edit: Working on trying to figure something out, will update with any progress. Also thank you to whoever edited my title!
Edit 2: Some mistakes were made in my attempt to show the equality. Looking at it again after taking a break I was able to show that indeed both sides of the equation are equivalent.
Not clear if you want to do this on your own, or if you need assistance.
Several approaches are possible. What path do you have in mind ?
[edit]
Can you tell us a bit more what you mean with that ?
Maybe my brain is just fried from too much studying, but I really cannot come up with where to start. I edited the post with an attempt to just show that the equality is valid, but that just confused me more. I would appreciate someone just giving me a full explanation but any assistance or hints you can provide would be great.
[edit]
Sure, I will try. I have dealt with plenty of problem where
functions such as
##\frac{1}{x^2-1}## which have denominators which are sums can be transformed into a sum of fractions via a Taylor Expansion. This is however an example where the denominator is already an infinite sum, and I do not understand how that can be separated into a sum of (infinite) terms. Does that make sense?
Edit: This all comes from an expansion of the sine function in the function ##g(z)=\frac{1}{z^4sin(z)}## in order to show that g(z) can be expressed as a Laurent expansion, in order to then discuss Cauchy Residue Theorem if that helps any.
your approach seems sound. in general, in my experience all computations of inverses of power series proceed from the basic; 1/(1-t) = 1 + t + t^2 + t^3 +..., using various substitutions for t.
In the step $${z^5\left(1-\frac{z^2}{3!}+\frac{z^4}{5!}-\frac{z^6}{7!}+...\right)}\left({\frac{1}{z^5}}+{\frac{1}{6z^3}}+{\frac{7}{360z}}+{\frac{31z}{15120}}+{\vartheta({z^3})}\right)=\left({z^5}-\frac{z^7}{3!}+\frac{z^9}{5!}-\frac{z^{11}}{7!}+...\right)\left({\frac{1}{z^5}}+{\frac{1}{6z^3}}+{\frac{7}{360z}}+{\frac{31z}{15120}}+{\vartheta({z^3})}\right)$$ you take the ##z^5## into the first bracket. It's easier to take it into the second.
Then you make a mistake: $$\Bigl (1-{z^2\over 6}...\Bigr )\Bigl (1+ {z^2\over 6} ...\Bigr )$$ has no terms of order ##z^2## !
Ok, after a good nights rest I revisited the problem and was able to properly prove the equivalence of both expressions. However it is still not clear to me how to go about expressing
##f(z)={\frac{1}{z^5\sin(z)}}={\frac{1}{z^5\left(1-\frac{z^2}{3!}+\frac{z^4}{5!}-\frac{z^6}{7!}+...\right)}} \mbox{ as a Laurent expansion } f(z)=\sum\limits_{n=-\infty}^{\infty}a_nz^n##
Edit: Mistakenly put ##\theta## as the argument of the sine function out of habit. Corrected to be ##z##.
As mathwonk suggested earlier in the thread, you use the Taylor series ##\frac{1}{1-t} = 1+t+t^2+\cdots##. Write
$$\frac{1}{z^5\left(1-\frac{z^2}{3!}+\frac{z^4}{5!}-\frac{z^6}{7!}+\cdots\right)} = \frac{1}{z^5(1-t)}=\frac{1}{z^5}(1+t+t^2+t^3+\cdots),$$ where ##t = \frac{z^2}{3!}+\frac{z^4}{5!}-\frac{z^6}{7!}+\cdots.##
Likes benorin
This is precisely as Knopp directs to divide power series in his book "Theory and Applications of Infinite Series," 2nd edition, pgs. 179-181.
OK that all makes sense. I believe I understand it now. Thank you everyone for your help and advice.
but watch your minus signs. for 1-t to equal 1 - z^2/3! + z^4/5! ..., you have to change the signs of every term after the 1, not just the first term z^2/3!, i.e. you need t = z^2/3! - z^4/5!...
