Mentor
- 50,866
- 26,879
Boing3000 said:There is no "claim" by defining absolute simultaneity by synchronized clock readings.
The term "absolute simultaneity" already has a definition--you can't just decide to use your own instead of the standard one.
Boing3000 said:What really bothers you is that "thing" is at two place. What bothers you is non-locality.
I have said nothing whatever about non-locality in response to you. I'm just responding to your incorrect claims about "absolute simultaneity". You are claiming that, if I start out two synchronized clocks at the same event and then let them separate, spatially separated events where they both read the same proper time provide "absolute simultaneity". That's not correct. (Also see further comment below.)
Boing3000 said:I am not either going to retract that time is absolutely measured by clock, proper clock. It would be nice if you could stop pretend to contradict what the entire edifice of relativity stands on.
The word "absolutely" is wrong. What "the entire edifice of relativity stands on" is that proper time is measured by clocks. But proper time is not "absolute"--it's just arc length along a timelike worldline. Such an arc length is invariant, yes--it's the same regardless of our choice of coordinates. But "invariant" is not "absolute". It's just "invariant".
Boing3000 said:It may not be, only an experiment could sort it out.
The prediction of QM is quite clear: the measurements should commute. (Provided that the electrons are not allowed to interact further when they come back together--further interaction would change their joint quantum state.) Given the initial entanglement and no further interaction, the prediction for the measurement results is the same regardless of where in spacetime the measurement events are--they can be spacelike separated, timelike separated, null separated, or even the same event.
A further comment: you seem to think that the proper time of the two electrons once they separate has something to do with determining the measurement results. It doesn't. Electron spin states are stationary, so they don't change with time; that means that, given the initial entanglement, it doesn't matter how much proper time elapses for each electron before a measurement on it is made. The QM prediction for the measurement results remains the same.
