Find the center of mass for a disk with cut outs | Solution
  • Thread starter Thread starter braindead101
    Center Mass
The discussion focuses on calculating the center of mass for a disk with a radius 'a' and three circular cutouts: one with a diameter of 'a' and two with a diameter of 'b'. The center of mass equations derived are Xc = Xo - a/2 and Yc = Yo, with additional insights on symmetry and mass distribution. The relationship between 'b' and 'a' is established as b = (2/3)a, and the effective mass of the disk with cutouts is calculated as m_0 = (7/9)M and m_1 = (1/4)M. The final position of the center of mass is determined to be x_c = (9/56)a.
  • Understanding of center of mass calculations
  • Familiarity with geometric properties of circles
  • Knowledge of mass density concepts
  • Basic algebra for solving equations
  • Study the principles of symmetry in physics
  • Learn about mass distribution in composite shapes
  • Explore advanced center of mass problems involving multiple cutouts
  • Investigate the application of calculus in determining center of mass
Students and professionals in physics, mechanical engineering, and mathematics who are involved in solving problems related to center of mass and geometric shapes with cutouts.
braindead101
question:
find the location of the center of mass for the following disk of radius a. it has a three circular cut outs. one with a diameter of a and the other two have a diameter of b.
http://img479.imageshack.us/img479/2743/physics4ld.jpg
solution:
Xc = m/m(Xo - a/2)
Xc = Xo - a/2
Yc = m/2m(Yo+L+b/2) + m/2m(Yo-L-b/2)
Yc = Yo
is this right...
ive no idea.
Is there any figure associated with the question? I don't think this can be solved without knowing the positions of the cutouts of radius 'b'
oops. there was some problem. now when using firefox the images have been loaded. (was using opera before). sorry
Here are 2 tips for finding the centre of mass:
1. The center of mass will always be on a symmetry axis
2. Instead of thinking of a disc with holes, try imagining a full disc of radius a, and more discs (of radii a/2,b/2) with negative mass where the holes are, so the net mass density where the holes are is zero. So you multiply all the areas of all the discs by their distance from the origin point, and divide by the sum the areas. Make sure you get the signs right: the area of the biggest disc should have a plus sign, while the others should have a minus sign.
Hope this helps
First of all, the picture shows up fine in Opera.
Second, I'm going to assume that the two smaller circles are tangent to both the one of radius \frac{a}{2} and the largest one at the top and bottom.
So we first must find b in terms of a by constructing a right triangle connecting the centers of each the largest, medium, and one of the smallest circles. Then:
(\frac{a}{2})^2 + (a - \frac{b}{2})^2 = (\frac{a}{2} +\frac{b}{2})^2
b = \frac{2}{3} a
Now, let's say the original circle with no holes in it had a mass of M. The mass m_0 of the circle with only the two smaller holes is then:
m_0 = M - M \frac{2 \pi (\frac{b}{2})^2}{\pi a^2} = \frac{7}{9} M<br />
The mass m_1 of the larger circle taken out is:
m_1 = M \frac{\pi (\frac{a}{2})^2}{\pi a^2} = \frac{1}{4} M
Let x_c be the distance to the right of the center of the biggest circle at which the center of mass that you wish to find is. The center of the circle is the center of mass of this piece and the medium sized circle.
\frac{7}{9} M x_c - \frac{1}{4} M \frac{a}{2} = 0
So, x_c = \frac{9}{56} a
The y coordinate of the center of mass has obviously remained along the horizontal line from the center. Of course I have probably made a mistake, but that's how you do a problem like this.
i don't understand why the bottom is pi a^2, it didnt say newhere in the question that the mass equals its area
  • · Replies 42 ·
  • · Replies 25 ·
