Mass, Density and Volume of atmosphere
The discussion focuses on calculating the mass of the Earth's atmosphere above a 1m² area at sea level, using the density formula ρ(h) = ρ0e^(-h/h0) with ρ0 = 1.3 kg/m³ and h0 = 8.2 km. The correct mass for 15 km of atmosphere is 8900 kg. Participants highlight errors in integrating the density function and emphasize the importance of using incremental height (dh) for accurate calculations. Misunderstandings about variable definitions and dimensional consistency are also addressed.
  • Understanding of atmospheric density equations, specifically ρ(h) = ρ0e^(-h/h0)
  • Basic calculus, particularly integration techniques for variable functions
  • Familiarity with dimensional analysis to ensure consistency in equations
  • Knowledge of mass-volume relationships in physics
  • Study the integration of exponential functions in physics contexts
  • Learn about dimensional analysis and its application in physical equations
  • Explore atmospheric science concepts related to pressure and density variations
  • Review common mistakes in variable substitution during calculus operations
Students studying physics, particularly those focused on atmospheric science or fluid dynamics, as well as educators looking to clarify common misconceptions in integration and density calculations.
Any Help
[/B]
The density of the Earth's atmosphere varies with altitude, and can be approximated by an exponential: ρ(h)=ρ0e^(-h/h0) where ρ0 = 1.3 kg/m3 (the approximate density at sea level) and h0 = 8.2 km (this is determined empirically). Calculate the mass of 15 km of the atmosphere above a 1m2 area at sea level.
Mass= density. volume volume= area . height
I tried to solve it in two different ways but both gives me incorrect answer, The correct answer is 8900kg
My First attempt
: I substitute the height in the equation then i got p(h)=1.3xe^(-15/8.2) p(h)=0.19936 kg/m^3
Mass= p(h) x volume =0.19936x area x height = 0.19936x1x15x10^3=2990.4kg but the answer is not correct?!
My second attempt: I expand the equation to get mass=V.p(h)=h.A.p0.e^(-h/h0) then integrate it to get mass= [h^2/2 . A.p0.e^(-h/h0)+ h.p0/h0 .e^(-h/h0)] from h=0 to h=15000
mass= 23478038kg also not correct!
It would be easier to follow your work if you defined all your variable names before using them.
So you have mass = V.p(h). V being the volume and p(h) being the density at the current height h.
You proceed to equate V to h.A where A is the surface area under a column of height h. But that's wrong. If you are integrating, the total height h does not contribute to the volume of an incremental element. Only the incremental height ##dh## contributes. You need to be adding up the masses of incremental volumes in the column.
Keeping track of units could have shown you that the result was dimensionally inconsistent.
You proceed to equate V to h.A where A is the surface area under a column of height A. But that's wrong. If you are integrating, the total height h does not contribute to the volume of an incremental element. Only the incremental height ##dh## contributes. You need to be are adding up the masses of incremental volumes in the column.
you mean that i should not integrate ? but in my first attempt i didn't integrate and the answer was also incorrect
No, I mean that you need to be careful what you integrate.
When you integrate, you are essentially adding up the masses of a whole bunch of incremental volumes starting at the base of the column and working your way to the top. What is the formula for the mass of an incremental volume of height ##dh## at altitude ##h## with area ##A## and density ##\rho(h)##?
When you integrate, you are essentially adding up the masses of a whole bunch of incremental volumes starting at the base of the column and working your way to the top. What is the formula for the mass of an incremental volume of height ##dh## at altitude ##h## with area ##A## and density ##p(h)##?
mass=area.p0.e^(-dh/h0)dh right?
No, that is not it.
Try it one step at a time. Do not substitute for the density yet. What is the formula for the incremental mass in terms of ##dh##, ##h##, ##A## and ##\rho(h)##?
jbriggs444 said:
Try it one step at a time. Do not substitute for the density yet. What is the formula for the incremental volume in terms of dhdhdh, hhh, AAA and ρ(h)ρ(h)\rho(h)?
the formula for volume for each dh is Area.dh and that for the density p(h)=p0.e^(-dh/h0)
right till now?
right till now?
No. That is not the formula for density.
p(h)= -p(0)/h0 .e^(-dh/h0) ??
By now you have seen and liked the complete solution that was posted by another helper and subsequently removed.
The problem with the above formula for density is that it is not a function of h. "h" and "dh" are different things.
yeah i put h in the equation instead of dh and that what made all my wrong going wrong
