Mass distribution of a semi-infinite stick
The discussion focuses on determining the density distribution of a semi-infinite stick such that it balances on a support located a distance l from its end when cut at any arbitrary location. The key equation involved is T = r x F, which relates torque to force and distance. The main challenge presented is differentiating an integral with respect to a variable that appears in the integrand and potentially in the bounds. The solution requires a clear understanding of differentiation under the integral sign, as outlined in the provided Wikipedia link.
  • Understanding of torque and force relationships in physics.
  • Familiarity with integral calculus, specifically differentiation under the integral sign.
  • Knowledge of semi-infinite structures in statics.
  • Ability to interpret mathematical problems involving variable dependencies.
  • Study the concept of differentiation under the integral sign in depth.
  • Review the principles of torque and equilibrium in static systems.
  • Explore advanced integral calculus techniques, particularly those involving variable limits.
  • Examine examples of density distributions in physics problems to understand practical applications.
Students of physics, particularly those studying statics and dynamics, as well as educators seeking to explain complex integral calculus concepts in a physical context.
Jzhang27143
Given a semi-infinite stick (that is, one that goes off to infinity in one direction), determine how its density should depend on position so that it has the following property: If the stick is cut at an arbitrary location, the remaining semi-infinite piece will balance on a support that is located a distance l from the end.
http://www.personal.kent.edu/~fwilliam/Chapter 1 Statics.pdf - Problem 18
T = r x F
In the linked solution, I understand the setup, but I do not understand how to find the derivative of the integral with respect to x0. Can someone give me a more detailed explanation of this step?
9K
