Mass launched up a ramp by a spring(friction)
  • Thread starter Thread starter BBQX
    Mass Ramp
The discussion focuses on calculating the maximum height reached by a block (M=2kg) propelled by a spring (K=2000 N/m) compressed by 10 cm on a rough incline with a coefficient of kinetic friction (μk=0.1). The approach utilizes the conservation of energy principle, equating the initial potential energy of the spring to the work done against gravity and friction as the block ascends the incline. Key equations include the potential energy of the spring and the work done by friction, with considerations for the incline's angle and the block's path affecting the calculations.
  • Understanding of conservation of energy principles
  • Knowledge of frictional forces and coefficients
  • Familiarity with basic kinematics and dynamics
  • Ability to apply trigonometric functions in physics problems
  • Explore the concept of conservation of energy in mechanical systems
  • Learn about calculating work done by friction in inclined planes
  • Study the effects of different angles on kinetic friction and motion
  • Investigate the relationship between potential energy and height in physics
Students studying physics, particularly those focusing on mechanics, as well as educators seeking to understand energy conservation and friction in inclined motion scenarios.
BBQX
A block M=2kg rests against a spring (K=2000n/m) compressed by 10cm. When released, the block is propelled up a rough(Mu-k=0.1) incline. What is the max height reached by the block?
https://www.physicsforums.com/attachment.php?attachmentid=11412&stc=1&d=1193953938
Well I was trying to solve this using Conservation of energy.
Ei+W=Ef
friction = muN
N= mgcos(th)
L= length of ramp
H= height
.5(2000)(0.1)^2= 2(9.8)Hsin(10)-(Fiction)Lcos(180)
I'm stuck here
and really confused... am i missing a term and how do i find "L"
I'm stuck here
I take it that you set the initial potential energy stored in the spring equal to the initial kinetic energy of the block when it departs from the spring. You then noted that both the work against gravity and the work done by friction will ultimately reduce the kinetic energy of the block to zero, thus determining where it will stop. So the work terms must equal the initial kinetic energy of the block on starting up the incline.
First question: was an angle for the incline given? It will make a difference because the kinetic frictional work does depend on the path taken by the block.
Second, don't forget that some of the spring's potential energy went into lifting the block against gravity while it was still in contact with the spring. Or is the spring on a horizontal surface and then the block starts up the incline after the spring is relaxed?
Third, I'm not clear from the way the problem is written whether they want the change in height of the block or the distance along the incline that the block slides.
By the way, your attachment doesn't display.
  • · Replies 21 ·
