AnswerMass of Aluminum: Calculating Heat Transfer to Reach Final Temp
  • Thread starter Thread starter DrMcDreamy
    Aluminum Mass
The discussion revolves around calculating the mass of a chunk of aluminum dropped into a steel container with water, where the final temperature remains at 24°C. The specific heats of aluminum (900 J/kg·°C) and copper (387 J/kg·°C) are provided. The heat transfer equation Q = mcΔT is utilized to determine the heat lost by the copper and the heat gained by the aluminum. The conclusion is that the mass of the aluminum can be derived from the heat balance, recognizing that the total heat exchange results in no temperature change in the water.
  • Understanding of heat transfer principles, specifically the concept of thermal equilibrium.
  • Familiarity with the specific heat capacity of materials, particularly aluminum and copper.
  • Proficiency in algebraic manipulation to solve equations.
  • Knowledge of the heat transfer equation Q = mcΔT.
  • Study the derivation and application of the heat transfer equation Q = mcΔT in various scenarios.
  • Explore specific heat capacities of other materials for comparative analysis.
  • Learn about thermal equilibrium and its implications in calorimetry experiments.
  • Practice solving problems involving multiple objects and heat transfer in closed systems.
This discussion is beneficial for students in physics and chemistry courses, particularly those studying thermodynamics and heat transfer principles. It is also useful for educators looking to enhance their teaching methods in calorimetry.
DrMcDreamy
I think this is more of a gen chem question, but this is for my physics lecture.
A student drops two metallic objects into a 240 g steel container holding 62 g of water at 24◦C. One object is a 186 g cube of copper that is initially at 75◦C, and the other is a chunk of aluminum that is initially at 4.6◦C. To the student’s surprise, the water reaches a final temperature of 24◦C, precisely where it started. What was the mass of the aluminum chunk? Assume the specific heat of aluminum and copper is 900 J/kg ·◦C and 387 J/kg ·◦C,respectively. Answer in units of kg
What is the formula that I am supposed to use for this? TIA
Q = mcT
Copper:
Q=mc\DeltaT
Q=(.186 kg)(387 J/kg C)(24 C -75 C)
Q=-3671.1 J
Aluminum:
But I am not given Q, so I have to solve for 2 things: Q and m
Q=mc\DeltaT
Q=m(900 J/kg C)(24 C -4.6 C)
Qm=(900 J/kg C)(19.4 C)
Qm=17,460 J/kg
Which doesn't make sense.
So what do I do?
You are given Q for Al, although not directly - think, what it means that the temperature has not changed?
Besides, watch your algebra:
Second doesn't follow from the first.
