Mass of chair on weighing scale and wall
The discussion focuses on calculating the mass of a chair resting on a weighing scale and a wall, with specific measurements provided. The scale reports a weight of 42.62 kg when upright and 26.82 kg when flipped upside-down. The chair contacts the scale at a distance of 0.4 m from the wall at an angle of 64 degrees, with friction coefficients of 1.02 (wall) and 1.16 (scale). The total force acting on the system is calculated to be 69.44 kg using the gravitational force equations.
  • Understanding of gravitational force calculations
  • Knowledge of friction coefficients and their application
  • Familiarity with basic physics concepts such as force and mass
  • Ability to solve problems involving angles and distances in physics
  • Study the principles of static equilibrium in physics
  • Learn about the application of friction in real-world scenarios
  • Explore the concept of forces acting on objects at angles
  • Investigate advanced problem-solving techniques in mechanics
Students studying physics, particularly those focusing on mechanics, as well as educators and anyone interested in practical applications of force and mass calculations.
dmouthfan2028
For what it's worth, I came up with this problem, so perhaps it cannot be solved, or there could be a way to solve it without using all of the information given.
A chair rests on a weighing scale and a wall. The relevant surfaces of the scale and the wall are perpendicular to each other. When upright, the scale reports 42.62 kg as its weight, but when flipped upside-down, the scale reports 26.82 kg. The chair makes contact with the scale at 0.4 m from the wall at an angle of 64 degrees. Frictional coefficient between the chair and the wall is 1.02, and between the chair and the scale is 1.16. What is the mass of the chair?
dmouthfan2028 said:
When upright, the scale reports 42.62 kg as its weight...
A correction:
When upright, the scale reports 42.62 kg as its mass...
Have I figured it out? Is this correct?
F_{gOnScale} = 42.62*9.81
F_{gOnWall} = 26.82*9.81
F_{T} = F_{gOnScale} + F_{gOnWall} = 42.62*9.81 + 26.82*9.81
F_{T}/a_{g} = \frac{42.62*9.81 + 26.82*9.81}{9.81} = 69.44\text{ kg}
