Mass of cylinder using ang.velocity
  • Thread starter Thread starter bigtymer8700
    Cylinder Mass
3 replies · 8K views
bigtymer8700
A light string is wrapped around the outer rim of a solid uniform cylinder of radius .375m that can rotate without friction about an axle through its center. A 3.00 kg stone is tied to the free end of the string When the system is released from rest, you determine that the stone reaches a speed of 3.50 m/s after having fallen 2.50m .
What is the mass of the cylinder?
Ive solved for:
F=M*a
3kg*9.8=29N
29N*2.5m=73.5J
i know its a solid cylinder so I=1/2 Mr^2 so i need to solve for the inertia. from here i got stuck i know i have to use
Kf=1/2mv^2+1/2Iw^2 i don't know where to go from here. do i solve for the angular velocity(w)? or Inertia?
i know v=rw so would w=v/r i could use 3.5m/s/.375m to get 9.3rad/s?
i used the Ki + Ui=Kf + Uf
Ki=0
Ui=mgy=73.5J
Kf=1/2mv^2+1/2Iw^2
Uf=0
i got
73.5=1/2Iw^2+18.375 so
1/2(I)w^2=55.125J
im stuck on Kf where i have to solve for the two unknowns I* w* i used v=rw to solve for w is that correct?
