Mass on a spring inside a box falling under gravity
The discussion focuses on the dynamics of a mass attached to a spring inside a massless box falling under gravity. The key equations of motion are derived using Lagrangian mechanics, where the kinetic energy (KE) is expressed as KE = 1/2 m ˙x² and the potential energy (PE) as PE = mgy + 1/2 kx². Initial conditions are established for both the falling phase and post-impact phase, with the mass's motion described by the equation &ddot{z} = -g. The analysis emphasizes that during free fall, the spring does not oscillate due to the uniform acceleration of the box, mass, and spring.
  • Understanding of Lagrangian mechanics
  • Familiarity with kinetic and potential energy equations
  • Knowledge of harmonic motion and spring dynamics
  • Basic principles of gravitational acceleration
  • Study Lagrangian dynamics in detail, focusing on systems with constraints
  • Explore the effects of damping on spring-mass systems
  • Investigate the behavior of oscillatory systems under varying gravitational conditions
  • Learn about the conservation of energy in mechanical systems
Students and educators in physics, mechanical engineers, and anyone interested in the dynamics of oscillatory systems and gravitational effects on mass-spring systems.
naggy
A mass m is attached to a spring(massless) that is located inside a massless box. The box is falling under gravity. When the box starts to fall the spring is in it's equilibrium position and the box sticks to the ground when it hits it.
-The box is a distance H from the ground
-Spring has spring constant k
-The mass on the spring is m
Find the equation of motion (and initial conditions) when
a)the box is falling and
b)when the box has landed.
Variables
x is movement from equilibrium position of spring
y is distance from ground to mass
L=KE - PE
or
F=m\ddot{x}
I prefer using Lagrangian equations. When the box is falling:
KE= \frac{1}{2}m\dot{x^2}
PE= mgy +\frac{1}{2}kx^2
Now can I connect y(distance from the ground to m) and x(movement from equilibrium position of mass) with y=constant + x and use the Euler lagrange equations?
I'm also not sure on intial conditions, it would be x(0)=0 and x'(0)=0 for the first eq. of motion
when the box lands, maybe x(tH)=H and x'(tH)=sqrt(2gH) ??
i think you're on the right track.. i would spilt it up to look at before & after impact separately
so define
x - spring extension
y - distance base of spring zero to ground
then z = x + y is distance from ground to mass
so say time of impact is t0
before landing everything is accelerating downward at g
so
x(t<t0)=0
x'(t<t0)=0
and
PE = my'^{2}/2
KE = mgy
directly before impact find
v0 = z'(t0) = y'(t0)
then inatantly after impact the box no longer moves
y(t>t0) = 0
y'(t>t0) = 0
and the intial conditions of the mass are
x(t0) = 0
x'(t0) = v0
what about the Potential energy of the spring?
And what is base of spring? Y is distance base to spring? Do you mean the springs equilibrium position?
hey naggy
the way i set it up y was the springs equilibirum position, howvere you can set it up howvver you like. i didn't write down the final energy equations, so you need to include the PE of the spring & gravitational PE in the final section
the main thing to realize is beofre landing everything will have constant downward acceleration of g.
when the box strikes it will have intially total energy in the form of KE of the spring. this will then oscillate between spring PE & mass KE, with some gravitational PE.
you can make life easier for yourself by choosing a spring equilibrium position that essentially removes the complication of gravity PE (where does the spring sit under gravitational force of math)
something that is bothering me
When the the box is falling:
\ddot{z}=-g but I don´t know the initial conditions here? z=x+y but I don´t know the height up to the mass I only know the height to the bottom of the box?
But does the spring oscillate at all during the flight down?
I would say no, in an idealised free fall acceleration of the box spring and mass will all be identical under gravity, so there will be nothing to cause relative motion, that is until the box lands & sticks
unless you are given something different in the initial conditions, this is how I would approach the problem
  • · Replies 17 ·
  • · Replies 36 ·
