Mass Ratio Q: Solving for Final Speed of 8km/s
  • Thread starter Thread starter cycam
    Mass Ratio
The discussion revolves around calculating the mass ratio required for a rocket to achieve a final speed of 8 km/s using the Tsiolkovsky rocket equation. The relevant parameters include an exhaust speed (v_ex) of 2100 m/s and a burn time of 50 seconds. The equation used is Δv = v_ex * ln(m0/m), where m0 is the initial mass and m is the final mass of the rocket. Participants clarified that the mass ratio can be derived directly from the known values without needing to determine the mass of the rocket itself.
  • Understanding of the Tsiolkovsky rocket equation
  • Basic knowledge of logarithmic functions
  • Familiarity with concepts of rocket propulsion
  • Ability to manipulate algebraic equations
  • Study the derivation and applications of the Tsiolkovsky rocket equation
  • Learn about the principles of rocket propulsion and exhaust velocity
  • Explore logarithmic functions and their properties in physics
  • Investigate the impact of mass ratio on rocket performance and efficiency
Aerospace engineers, physics students, and anyone interested in rocket science and propulsion systems will benefit from this discussion.
cycam
A single-stage rocket is fired from rest from a deep-space platform, where gravity is negligible.
If the rocket burns its fuel in a time of 50.0 s and the relative speed of the exhaust gas is v_ex=2100 m/s, what must the mass ratio m_{0}/m be for a final speed v of 8.00 km/s (about equal to the orbital speed of an Earth satellite)?
v-v0= -v_exln(m/m0) = v_exln(m0/m)
having a rough time understanding the equation, any tips or hints?
Any help would be greatly appreciated.
I wonder if you are supposed to make a formula for the mass ratio as a function of time (it does vary). Is the mass lost at a constant rate?
It doesn't say that it has to be which i would assume it shouldn't be. All I know about the question is what you see. So to answer your question, i don't know. I was hoping someone would be able to answer that lol.
Does the rocket start from rest? If so, and you only care about the mass ratio and t=50 sec., then you just have to work out the log equation.
Yes, it appears that it is starting from rest. How would I go about finding the mass ratio? Also, the log equation?
How do I go about finding the mass of the rocket? (is that even the right question to ask)
updated the original question.
I'll help with the equation. It is known as the Tsiolkovsky rocket equation.
\Delta v = v_{\text{exhaust}}<br /> \ln\left(\frac{m_{\text{init}}}{m_{\text{final}}}\right)
where
v_{\text{exhaust}} is the exhaust speed relative to the rocket
m_{\text{init}} is the initial (pre-burn) mass of the rocket
m_{\text{final}} is the final (post-burn) mass of the rocket
\ln(x) is the natural logarithm function.
The problem gives v_{\text{exhaust}} and \Delta v and simply asks for the mass ratio {m_{\text{init}}}/{m_{\text{final}}}. Can you proceed with this?
Let me do the math really quickly and i'll show you what I got.
so is it MR=v_delta/v_exln?
ok, i got it. thank you =)
16K
