How Does the Velocity of a Suspended Mass Change with Height?
  • Thread starter Thread starter zibs.shirsh
    System
The discussion focuses on a physics problem involving a 5kg mass suspended by a string and subjected to a downward force of 500N, which decreases by 30N for every meter the mass is raised. The calculations show that the velocity of the mass when it reaches a height of 10m is 10√12 m/s. To determine when the direction of the velocity changes, it is concluded that this occurs at a height of 30m. The participants also discuss using the work-energy theorem to approach the problem, emphasizing the need for integration due to the changing force. Overall, the conversation highlights the correct application of physics principles to solve the problem effectively.
zibs.shirsh
A body of mass 5kg is suspended at the lower end of a mass-less string, which passing through a mass-less pulley and is being pulled down at the other end by a force of 500N.
The force of the pull reduces at a rate of 30N per meter, through which the body is raised.
What is the velocity of the body when it reaches a height 10m, starting from rest?
At what height will the direction of velocity change?
a=dv/dt=v.dv/dx
T-mg=ma
T=f, where f = F-30y
so basically, F-mg=ma
starting from F-mg=ma, i went to deriving:
(F-30y)-mg=m(dv/dt)=m.v.dv/dy
so, (F-mg)*y -15(y^2) = (m/2)v^2
=> (500-5*10)*10 - 15*(100) = (5/2)v^2
=> 4500 - 1500 = (5/2)v^2
=> 1200 = v^2
so v = 10√12 (that's my answer)
for the velocity to change direction, it must first become zero again - so putting zero as the initial and final values limits of integration, i got:
(F-mg)*y -15(y^2) = 0
=> [F -mg -15y]*y = 0
so y = 0 or (F-mg)/15 = 30
as y=0 is starting point, it can't be accepted as the required answer
hence, at y=30, the block will change it's velocityIS WHAT I DID CORRECT?
Everything looks good.
Note you could have obtained your results more "physically" by using work/energy explicitly.
Can you please show me how to do that - just a short, brief set of instructions will do
The change in the kinetic energy of the body is given by the work of the resultant force. This leads directly to the equation you obtained through integration.
But since the force is changing it will still require integration, no?
zibs.shirsh...This is how you would approach using work energy method
Let T be the variable tension in the string .Displacement of mass is considered positive upwards.
ΔT/Δx=-30 N/m
Integrate with proper limits and you would get T as the function of x .
Now apply work energy theorem ,∫Tdx = ΔKE + ΔPE .
so the fact that the question mentions a spring is just a red herring...?
There is no spring in the question. There is a string.
  • · Replies 21 ·
  • · Replies 27 ·
  • · Replies 97 ·
