Mass transported at speed of light
In summary, the conversation discusses the concept of accelerating an electron to the speed of light and how it would require infinite energy to do so. The discussion then moves on to the idea of an electron and a positron annihilating to form a gamma ray, which can travel at the speed of light. However, it is noted that the gamma ray is not the same as the electron, and the energy from the annihilation may be utilized in another electron, but it is not the same particle. The conversation ends with a reminder that while mass and energy are related, they cannot be freely interchanged without proper understanding and justification.
B.E.M
71
You cannot acelerate an electron to the speed of light without infinite energy right? ditto for a positron. And if you succeeded, who would know. the infinite mass would cause the visible universe to disappear up its own navel.
However, an electron and a positron can annihilate to form a gamma ray (given something at this end to balance the momentum), the gamma ray can move some distance at the speed of light, encounter some thing else and split back into an electron and positron..
So the net result is that some mass has 'transported' itself at the speed of light without 'moving' at the speed of light.
How can such a subtle distinction prevent the universe from ending?
B.E.M said:
You cannot accelerate an electron to the speed of light without infinite energy right? ditto for a positron.
Actually it would perhaps be better to say that we do not observe an electron to move at c.
It seems to me that there is nothing in QM that prevents an electron to move at c. But since it's path is not straightforward but random, the effective speed is lower than c.
Interesting here may be to consider the Dirac equation where electrons "wiggle" at c.
But perhaps the QM experts can give a more accurate description.
Good Point
that electron disappeared...into a gamma ray.. which became ANOTHER electron..
there were 2 electrons, thus 1 electron did not travel at the speed of lightIf you want to argue that somehow this 2nd electron could have been the first.. get out the heavy math graph paper
Shouldn't you ask this the other way? You might want to consider that since the universe did not end and did not encounter the catastrophe you described, then there must be something wrong with your description.
The fact that light can travel at c but object with a mass cannot, clearly shows that light and mass are NOT identical entities! Being converted from one to the other does not make them the same thing. I can convert my paper money into a very lovely paper mache sculpture. Would you accept that as payment for your salary?
Zz.
Although the energy of the gamma ray is the same as the electron, it is not the electron. Whatever properties the electron had, ceased when it was annihilated, including its mass, leaving just the energy which cannot be destroyed.
The energy may well be utilized in another electron, but it wouldn't be the same electron, just as a newspaper made from recycled newspapers can never become the original newspaper that was recycled. Universal Recycling.
Far from ending the Universe, it may well be what keeps it ticking over.
But my point is that we are observing it to move at c. in the sense that we detect a some mass (that has rest mass) in two separate locations at two separate times, separated by ratio c.
I don't even know if a stationary electron is the same particle a second later... brb
Yes, so long as you can convince the banks of this 'conservation of paper money' prinicple so they are willing to convert it back for me.
B.E.M, before starting to enter the realm of more advanced physics, perhaps it wouldn't be such as bad idea if you got some kind of profound understanding of more introductory physics?
[tex]E = mc^2[/tex]
That right there, is perhaps one of the most misinterpreted equations of all time by the public. Sure, you can say that mass and energy are the same, but how much does that actually make you understand?
[tex]s = vt[/tex]
After all, the above equation doesn't mean that distance and velocity is them same, now does it? It isn't perhaps the best example, but it should get you on the right way.
Yes, from the special theory of relativity, that mass and energy are both but different manifestations of the same thing. But that does not mean that you can do any conversions and transformations as you please and call it whatever you want. Yes, modern scientists do not separate mass and energy in some areas of the discipline. But that doesn't mean that you can do any transformation you wish with whatever explanation you want. Yes, annihilation and pair production works, but that still doesn't mean that you can do any conversions you want for whatever reason you have in mind.
In short, it can be said to be related to the correspondence principle. New theories must be compatible with old ones in situations where they are both applicable. The correspondence principle tells us that we can still use an old theory within the realm where it works, that is, there is no point in bringing up the conservation of mass-energy when we are dealing with how much energy it takes to heat a gram of water one degree Kelvin.
It isn't as easy as just "Let's turn an electron to energy" and start using the mass of an electron with the E = mc2 formula. There are more conservation laws in the Universe besides the conservation of mass-energy, which one you have stated yourself, conservation of momentum.
However, there is also conservation of charge and conservation of spin. An electron has a charge of -1, a photon has a charge of 0. An electron has a spin of +1/2, while a photon has a spin not equal to +1/2. That is why annihilation that includes an electron, must also include a positron. That way, both charge and spin is conserved. ZapperZ made a more exhaustive post on this a while back I believe, but I cannot seem to find it right now.
I accept that in some sense it may not be the same electron, but it sure looks the same. As far as I know there is no test to distinguish them. So also I suppose there is no reason we will not encounter some cream pie flying towards our face at the speed of light because at some microscopic level, maybe it is not traveling as matter at all.
(im not trying to be facious there, I actually find the thought sort of cool. Perhaps we could find a way to adjust matter so it sort of slides along at the speed of light, because in reality it is not moving, just exchanging itself with identical particles.)
Are you willing to stake your livelyhood on this? When was the last time this has happened?
If I were running the bank, I would not, especially if the dollar bills have been pulverized. In fact, in many countries, such destruction to the currency makes it no longer of legal tender.
A photon is not identical to electron+positron. If you insist that it is, then you're doing some new physics that hasn't been formulated and verified yet. It is as simple as that.
Zz.
The mutual annihilation of an electron and a positron results in two gamma rays.
Each gamma ray contains exactly the same amount of energy as the electron or the positron and all spin and charge is canceled out.
ah, actually I forgot about the second gamma ray.. I presume that potentially there might be only one gamma ray if something like a proton is present to balance the momentum etc? i.e an exact time reversal of a gamma ray splitting into two particles? (perhaps the second gamma ray hits the proton to transfer momentum?)
ps: I agree the banks would be hard to convince. Thus the fine print:wink:
Yes, but they are STILL not identical. One has zero invariant mass, the other do not. In particle detectors in high energy physics experiments, one has different signature than the other.
A photon is not made up of electron+positron, the same way a neutron is not made up of a proton+electron+antineutrino+others. There is a difference between the entity and the products it came from or decay to.
Zz.
Ummm, no. It can be proven (mathematically) that the result of the positron -electron collision is TWO photons, not one. You can do that yourself by calculating the norm for the 4-vector energy-momentum for the electron-positron pair : it is greater than zero (one photon corresponds to zero).
The positron-electron annihilations produces TWO photons that travel in opposite directions.
You can use the same math as above to prove that :
1. in an empty region of space a photon cannot decay into an electron -positron pair (same calculations as above)
2. the photon CAN produce an electron-positron pair in the vicinity of a nucleus. The presence of the nucleus is KEY in the creation of the electron-positron pair. So, this situation is NOT the REVERSE of the situation that created the photon in first place.
This does NOT mean that for a while, the positron-electron have traveled at c.
No. I hope that now you understand why.
Maybe it helps to think sometimes in terms of relativistic- (rather than rest-)mass, which stays constant in your scenario. An electron particle cannot spontaneously accelerate toward the speed of light, because something else would need to somehow add to the electron's relativistic mass (toward infinity). However, it can spontaneously change into another form with the same relativistic mass (such as a photon with particular frequency) provided various other physical constraints are satisfied (eg. being faster, the photon has more momentum, so momentum-conservation may demand that another particle be transformed at the same time, and if both are transformed to photons then charge conservation requires the other to be a positive particle with electron mass..).
Hi nakurusil,
I think both of these points were dealt with. for example
Of course two particles at rest (0 momentum )cannot become one particle at speed of light (some momentum in some direction) without something to balance the momemtum. You don't need to talk about solving 4-vectors.
Secondly, basically everything in physics is reversable. I was assuming protons as bookends, but presumably two gamma rays can spontaniously form an electron-positron pair also.
Im not claiming a flaw in physics here.
cesiumfrog said:
Maybe it helps to think sometimes in terms of relativistic- (rather than rest-)mass, which stays constant in your scenario. An electron particle cannot spontaneously accelerate toward the speed of light, because something else would need to somehow add to the electron's relativistic mass (toward infinity). However, it can spontaneously change into another form with the same relativistic mass (such as a photon with particular frequency) provided various other physical constraints are satisfied ..
Thats reasonable: rest mass is not that fundamental, I am really just looking for a way at looking at this that makes in clear why there is a hard way and and easy way to move mass and information between two points.
btw.. I have always assumed that energy that stays in one place acts like rest mass. Is this true? For example if you had two photons bouncing in opposite directions (so zero momentum) inside a massless mirrored box then it would act like a stationary piece of mass. If you tried to push this box up to the speed of light, the wavelength of the photon opposing your travel would approach infinity while the other would redshift towards zero.
If true, this could be a good thought-example of how restmass is just a configuration.
B.E.M said:
Hi nakurusil,
I hope you are at least slightly embarrassed when you re read this thread and realize both of these points were dealt with. for example
Not at all, you understood zilch from what I tried to explain to you.
The positron - electron entering annihilation DO NOT have zero momentum, what gave you the idea?
You don't "solve" 4-vectors, one uses them in order to calculate relevant information in solving the problem. I was going to give you the detailed solution, now I am glad that I didn't waste my time typing it up for someone who would not appreciate it.
But the situation that you chose (positron-electron annihilation in vacuum) is not reversible as I have just showed you. You will not get a photon to produce an electron-positron pair UNLESS there is a nucleus present. I was going to ask you to calculate why this is true but based on your previous answers it is clear that you wouldn't know where to start.
Hi Nakurusil,
Sorry for being snippy before. I had just edited my post slightly to remove that first line. I think that line was the real cause for this disagreement.
I think these misunderstandings here must be based on subtle misswordings. Generally what you say makes sense but I am not making the claims you think I am.
apologies again for ruining this beautiful friendship. :)
When the electron and positron are annihilated, spin and charge cancel each other out and the total energy at the end is the same as before, but what happens to the mass ?
The two gamma rays produced have no mass, so what has happened to it ?
But isn't that the point that I brought up to counter your argument? One has no invariant mass, the other does!
Nothing happened to the mass. The requirement that we account for mass not "disappearing" comes from the old conservation of mass law. While that works in many instances, we now know that the more general conservation law is the conservation of mass+energy, i.e. as in [itex]E + mc^2[/itex], not just mass alone or energy alone.
So if you consider that more generalized law, then there's no more asking about where the mass went.
The fact that there is a conversion from one to the other means that the original entity is not the same as the final entity (or else, why bother with a "conversion" in the first place). Water and ice are not identical entity even when both are made up of the same "thing". So if something that we know as simple as a process that undergoes a first order phase transition can be different, we certainly can say that a more profound and complicated conversion between mass and energy should be even MORE different.
Zz.
But they have energy, remember [tex]\Delta E =c^2 \Delta m[/tex] ? This is what happened to mass.
The same amount of energy exists after the annihiliation as before. [tex]\Delta E =c^2 \Delta m[/tex] is not what happened to the mass.
I was going to say 'isnt mass equivalent to energy'? but I just read on wiki that this statement is not popular now as it leads to confusion between invarient mass and the less popular 'relativistic mass'
http://en.wikipedia.org/wiki/Mass_in_special_relativity" [Broken]
quote form the article:
Another way of expressing this idea is that if released energy is allowed to remain in a system (for example, as heat, or even trapped radiation), this energy will be measured as, and included in, the ordinary "rest" mass of the system (that is, this energy still contributes to the inertia of the system and its gravitational field).
Since you know, there is no point in explaining to you. Based on your initial question, it is clear that you don't know. If you really want to learn, ponder on the [tex]\Delta[/tex]
Doesn't the invariant mass refer to that of the system (electron+positron) taking into account the total energy and momentum of the system ?
Say what?
Tell me the invariant mass of the electron+positron, and the photon after anhilation.
Zz.
The invariant mass of the electron+positron before the annihilition is equal to the invariant mass of the TWO photons after the annihiliation.
Invariant Mass is a method of basically ignoring the Mass bit by referring to the energy and momentum instead, it's not a way of cancelling out mass in the same manner as spin and charge can be canceled out.
Adding Mass and Invariant Mass is like adding Lemons and Oranges; they're both citrus, but they're not really the same thing.
An electron has mass and invariant mass as does the positron, although when dealing with their mutual annihiliation, only the invariant mass is really relevant.
So you are saying that photons have invariant mass, no? Can you point to me a legitimate source that claim such a thing?
Zz.
I'm saying that a system of photons has invariant mass, as in the case of the two gamma rays resulting from the annihilation of the electron and positron.
http://en.wikipedia.org/wiki/Relativistic_mass" [Broken]
Even for photons, a single observer and a closed system is required for mass conservation, since photons as considered singly have zero mass, where as pairs or systems of photons moving in different directions will in general exhibit an invariant mass which is associated with the system of photons, but not with any single photon.
Hence why they must be viewed as a system.
My initial question really referred to the Relativistic Mass, incidently which both the electron and positron can be viewed as having prior to their destruction.
I challenge your wikipedia source with http://math.ucr.edu/home/baez/physics/Relativity/SR/light_mass.html" [Broken]:
. By convention relativistic mass is not usually called the mass of a particle in contemporary physics so it is wrong to say the photon has mass in this way. But you can say that the photon has relativistic mass if you really want to. In modern terminology the mass of an object is its invariant mass which is zero for a photon.
I will also put it to you that I can go into Wikipedia and edit out that quote. So what guarantee do you have that it will be there tomorrow?
BTW, what does "relativistic mass" have anything to do with this? The electron-positron anhilation does NOT require the electron and positron to be relativistic.
Zz.
  • #31
I really do not see why you challenge AWolf's assertion. It is definitely true.
There must be some misunderstanding.
  • #32
One can certainly calculate the quantity [itex]\sqrt{E_{total}^2 - (p_{total} c)^2}[/itex] for the pair of photons, and it must equal the similar quantity for the electron and positron. But how meaningful as "mass" is that quantity for an unbound system as opposed to a bound system? One can (at least in principle) "weigh" a box with mirrored walls that contains a bunch of photons, and find that it has a greater mass than a similar box that does not contain any photons. But how does one "weigh" a system of photons that are not confined? For that matter, how does one "weigh" a system of positron + electron that are not confined or bound together?
  • #33
Both sources agree that a photon does not have invariant mass. Find a source that refers to multiple photons viewed as a system having no invariant mass and then you'd have a valid challenge, oh, but hang on a minute, Baez does mention multiple photons.
From your Baez link
However, modern usage defines mass as the invariant mass of an object mainly because the invariant mass is more useful when doing any kind of calculation. In this case mass is not conserved and the mass of an object is not the sum of the masses of its parts. For example the mass of a box of light is more than the mass of the box and the sum of the masses of the photons (the latter being zero).
The point about Relativistic Mass is with regards to how much of the Universe does an electron or a positron occupy. When the two are annihilated, the resulting photons do not occupy the same space.
  • #34
Read again. When CONFINED TO A BOX, as in the photons have been localized so that you can actually measure a change in mass OF THE BOX.
Read ALL the caveats that he put in there in making sure people RESIST the temptation of putting any mass on photons, be it single or multiple.
This is still besides the point. Show me exactly what the "photon invariant mass" is.
Zz.
  • #35
Hi Zapper, these don't actually contradict.
Consider two photons moving in opposite directions
Their momentums cancel in the systems rest frame, yet the system still has energy. This energy is equivalent to the system's invarient (or rest) mass even though the individual photons have no rest mass.
