Material properties of Heavy water
The discussion centers on the thermophysical properties of heavy water needed for computer simulations, specifically at a reference temperature of 40°C and 6.549 kPa. The user inquires about the accuracy of several properties, including density, specific heat, dynamic viscosity, thermal conductivity, kinematic viscosity, and the Prandtl number. Responses include links to relevant resources for verifying these properties. The user expresses gratitude for the quick replies received. Accurate thermophysical data is crucial for effective simulations involving heavy water.
sunilpatil
Hello sir,
I am new to this forum i am looking for thermophysical properties of heavy water for my computer simulation. following properties i found in the wed. can anyone suggest me that these considered properties are correct
(ref temp 40 C and 6.549 kPa)
density = 1099.99 Kg/m3
specific heat at constant pressure = 153.36 KJ/Kg or 2230.8 Kj/kg (which one is correct)
dynamic viscosity = 7.848e4 Pa s
Thermal conductivity = 610.2e3 W/m K
Kinematic viscosity = 0.7135e6 m2/s
Pr = 5.443
Thank you
Sunil
Hello sir,
Thank you for your quick reply.
Hello, I am designing an X-ray irradiator with MCNP simulation. But I am still in confusion, whether my X-ray housing will be a box or a cylinder. If the box (macrobody identifier of MCNP) is required, I am trying to match the dimension as that of the cylinder, i,e, the height will be that of the cylinder height, and the other two dimensions will be that of the radius of the cylinder (surface 52 and 53). Can anybody please help me define the surfaces? Below is my attached text file. Forgot...
  • · Replies 16 ·
18K
