Mathematical model of pendulum
The discussion centers on the mathematical model of an ideal pendulum, specifically focusing on the total energy per unit mass equation and its constancy over time. Participants analyze the energy equation E(θ, θ̇) and its derivative, aiming to demonstrate that energy remains constant as per the initial conditions of the pendulum. Confusion arises regarding the correct application of derivatives in the energy equation, particularly concerning the terms involved. Ultimately, it is clarified that the constancy of energy leads to the conclusion that the pendulum's motion satisfies the derived equation, linking the energy state to the initial conditions. The conversation emphasizes the importance of correctly interpreting the energy dynamics of the pendulum system.
limofunder
W
We know the model of an ideal pendulum at rest is given by
L \ddot{\theta} + g sin \theta =0, t\geq0
\dot{\theta}(0)=0
\theta(0)=\theta_0
where \theta(t) is the pendulum angle at time t, L is the length of the pendulum, and g is gravity.
Now, consider the total energy per unit mass of the pendulum given by
E(\theta,\dot{\theta}) = \frac{1}{2}L \dot{\theta}^2 - g cos \theta
Show that this equation is constant along the previously given solutions (the first 3 equations initially given, let's call them EQ [1] ), \forall t\geq0. Use this result to show that the solution of [1] should satisfy
\frac{1}{2}L\dot{\theta}^2-g cos \theta + g cos \theta_0 = 0, \forall t\geq0
(lets call this EQN [2])
we know that if E(theta, thetadot) is a constant, then
\frac{d E(\theta,\dot{\theta})}{dt} = 0
so, taking the derivative of the energy, we have:
\frac{d E(\theta,\dot{\theta})}{dt} = \frac{d}{dt}[\frac{1}{2} L \dot{\theta}^2 - g cos \theta]
= L \ddot{\theta} +\dot{\theta}g sin\theta
however, this does not seem to equal [1], as \dot{\theta}gsin\theta never appears in the solution. what am I doing wrong?
or do we not take the time derivative of the second term in the energy equation (the sin(theta) term), thus giving
\frac{d E(\theta,\dot{\theta})}{dt} =L \ddot{\theta} +g sin\theta which is equal to zero by definition of [1], thus if the derivative of the energy equation is equal to zero, then by definition of constant, energy is constant!
now, i am in confusion as how to use this result to prove EQN [2]?
Hi limofunder! :smile:
(have a theta: θ :wink:)
hmm :rolleyes: … d/dt (Lθ') = Lθ''
but d/dt (Lθ'2) = … ? :smile:
\frac{d}{dt}\left(\frac{1}{2} L \dot{\theta}^2\right)=L\dot{\theta}\ddot{\theta}
:wink:
EDIT: Tinytim beat me to it
ok, so then that gives way to
dE/dt = θ' (Lθ''+g sinθ)
the second term being by definition of [1] >= 0 for all time.
Thank you,
so that still begs the question, I do not see how this forces
[1] to satisfy
1/2 Lθ' - g cosθ + g cosθ0
Thank you,
[1] to satisfy
Because E = constant is a solution, so just call the constant gcosθ0 :smile:
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 19 ·
