Can You Help Me Fix this Matlab Error in My Code?
  • Thread starter Thread starter bert2002
    Error Matlab
The MATLAB error arises from incorrect syntax, specifically the use of curly brackets {} instead of parentheses () for mathematical operations. Additionally, the division operator should be element-wise, requiring the use of '1./B' instead of '1/B'. The discussion clarifies that the dot operator in MATLAB is essential for distinguishing between array and matrix operations. Understanding these syntax rules is crucial for resolving errors in MATLAB code. Properly adjusting these elements will help fix the code and allow it to run successfully.
bert2002
Hello, i have a MATLAB code that simply lists a bunch of parameters with values and an equation that relates all of them together. I am getting on error that says
Error in ==> randelltest at 17
Ys0=Yl*{(Pm-Pc)*Yc/Yl*(1-Av*Tm/2*Yc/Yl)-Av*Tm*Pm/2}*(1-1/B);
Is there a problem with this syntax somewhere ?
Code in full (matlab noob)% ParametersYl=100; % initial lithosphere thickness
Yc=30; % Initial crustal thickness
Pm=3400; % mantle density
Pc=2670; % crustal density
Ps=2670; % basin material density
Av=2.4*10^-5; % volumetric coefficient of thermal expansion
Tm=1300; % mantle temperature at top of asthenosphere
B=(1:0.1:4); % stretching factor
% Equation for fault controlled subsidence
Ys1=Ys0/Pm(1-Av*Tm)-Ps;
plot(B,Ys1)
The brackets {} have a special meaning related to MATLAB cells, so you should replace them with (). You should also replace '1/B' with '1./B', so you get element-wise, and not matrix, division.
bert2002 said:
Ys1=Ys0/Pm What operator goes here? (1-Av*Tm)-Ps;
Thanks for clearing that up, what is the purpose of the "." ? I cleared up the other error you pointed out too.
16K
11K
