Matlab summation of a complex function
4 replies · 5K views · last reply
Waxterz
Hi,
I need to plot the last function of this:
Typeset equations: S_a(theta) equals the sum from i = 1 to K of exp(j k0 (K - i) d [sin(theta) - sin(theta0)]), followed by 20 log(|S_a(theta)| / 8).
But I don't know how to generate the sum. I know the for loop is totally wrong, but I can't go any further. This is what I have:
MATLAB editor window titled Untitled.m containing a script that sets K = 8, L = 950*10^-9, g = 2*pi/L, v0 = 30, v = -90:10:90, d = 950*10^-9, then a for loop over i = 1:8 computing S = exp(1i*g*(K-i)*d*(sind(v)-sind(v0))), followed by A = 20*log(abs(S)/8).
K = 8;
L = 950*10^-9;
g = 2*pi/L;
v0 = 30;
v = -90:10:90;
d = 950*10^-9;
for i = 1:8;
S = exp(1i*g*(K-i)*d*(sind(v)-sind(v0)));
end
A = 20*log(abs(S)/8);
A
Can someone fix the summation loop part for me?
Thanks in advance
You need to set S to zero before the loop, then
Code:
S = S + exp(1i*g*(K-i)*d*(sind(v)-sind(v0)));
Code:
Hi DrClaude,
I posted it on the forum, just in case I didn't found the answer myself. I knew it had something to do with setting something on zero. :)
So I tried something, I tried this:
K = 8;
L = 950*10^-9;
g = 2*pi/L;
v0 = 30;
v = -90:10:90;
d = 950*10^-9;
Ssum = 0;
for i = 1:8;
Ssum = S + Ssum;
end
A = 20*log(abs(Ssum)/8);
AIs this equivalent to yours? Thanks for your help and quick reply, btw.
Yea, I'm going to do your version. Got the inner matrix dimensions degree error. Anyway thx!
Waxterz said:
Hi DrClaude,
K = 8;
L = 950*10^-9;
g = 2*pi/L;
v0 = 30;
v = -90:10:90;
d = 950*10^-9;
Ssum = 0;
for i = 1:8;
Ssum = S + Ssum;
end
Your use of Ssum is better if you need ##S_a## afterwards. But I see a few things that could be better, and one error.
First,
Code:
for i = 1:8;
would be better as
Code:
for i = 1:K
since K is already defined. Second, since Ssum will be an array (as is S), you should initialize it as an array of zeros:
Code:
Ssum = zeros(19,1);
Finally,
Code:
Ssum = S + Ssum;
will not work. What happens at the first and last iterations of the loop?
