Express Plane V as Kernel & Image of Matrices A & B | Homework Solution
  • Thread starter Thread starter Tonyt88
    Kernel Matrix
The discussion focuses on expressing the plane V defined by the equation 3x1 + 4x2 + 5x3 = 0 as the kernel of a matrix A and the image of a matrix B. It emphasizes that the kernel will have a dimension of 2, indicating a plane in R^3, while the row space will have a dimension of 1. Participants suggest finding two linearly independent vectors that span the plane to construct matrix B's column space. Additionally, there is a reminder to review the definitions of "kernel" and "image" for clarity in solving the problem. Understanding these concepts is crucial for successfully completing the homework assignment.
Tonyt88
Express the plane V in 3 with equation 3x1+4x2+5x3=0 as the kernel of a matrix A and as the image of a matrix B.
{Note: the 1,2, and 3 after the x are subscript}
Would the relevant matrix just be a [3 4 5] with an image of 3?
Plane V in 3 ? Do you mean in R^3?
You have a lot of room to play with here, since there is not just one single example. Hints:
For the first part, the dimension of the null space is that of a plane (in R^3) and is of dim 2. The dimension of the row space would be 3-dim null space=1.
For the second part, I would try to find two vectors that span the given plane (remember 3rd semester calc with analytic geometry? Remember how to find the normal to a plane and how to get two linearly independent vectors perpendicular to that normal?) . That would give you the col. space of the matrix. As you need three columns, you can take one of the col.'s to be a linear combination of two others you have derived.
Good Luck
Do you understand that you are asked for two matrices, A and B?
You might want to review the definitions of "kernel of a matrix" and "image of a matrix".
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
15K
  • · Replies 36 ·
