Matrix Multiplication and Evaluation: B & A
  • Thread starter Thread starter James09
    Matricies
The discussion focuses on matrix multiplication and evaluation, specifically the multiplication of matrices B and A, where B is defined as (12, 14, 15; 1, 1, 12) and A as (1.2, 1; -0.6, 0.8; -0.1, -0.9). Users clarify the correct approach to matrix operations, emphasizing the importance of maintaining the correct orientation of rows and columns. Additionally, the conversation touches on hexadecimal representation, with users explaining how to convert color values from hexadecimal to decimal.
  • Understanding of matrix multiplication principles
  • Familiarity with hexadecimal number systems
  • Basic knowledge of sequences and series in mathematics
  • Experience with scientific calculators, specifically the El-W531 model
  • Study matrix multiplication techniques and properties
  • Learn about hexadecimal to decimal conversion methods
  • Explore the concepts of geometric sequences and their formulas
  • Investigate the functionality of the El-W531 calculator for advanced operations
Students, educators, and professionals in mathematics or computer science who are working with matrix operations, hexadecimal conversions, or sequence evaluations will benefit from this discussion.
James09
where possible evaluate the following
B A
B= (12 14 15 ) A= ( 1.2 1 )
( 1 1 12 ) (-0.6 0.8 )
( -0.1 -0.9 )
What did you try already?? If we know where you're stuck, then we'll know how to help...
3B - 2E
12 14 15 X3 36 3
1 1 12 28 3
45 36
13 12 17 X2 26 6
3 19 -8 24 38
34 -16
26 6 36 3
24 38 + 28 3
34 - 16 45 36
62 9
52 41
79 20
thats one I done earlier am I doing it the correct way??
James09 said:
3B - 2E
Code:
12 14 15  X3       36   3
1   1  12            28    3
                        45   36
13 12 17   X2      26   6
3  19 -8             24   38
                       34    -16
26  6                36  3
24 38     +         28  3
34 - 16             45 3662  9
52  41
79 20
No, when calculating 3B or 2E, you seem to replace columns with rows and vice versa. I don't know why you do that. Here's an example
4\left(\begin{array}{cc} 1 & 2\\ 3 & 4\\ 5 & 6 \end{array}\right)=\left(\begin{array}{cc} 4 & 8\\ 12 & 16\\ 20 & 24 \end{array}\right)
Thanks for the help lads
I've got a sharp El-W531 Calculator how to you do to the power of a minus number for example 5 * 8 to the power of -3?
And Can someone tell me what D is in base 16?
Q. A color is represented by the following string #10FAE2. Explain the meaning of this?
The answer is given as
Red 1016 = 16
Green FA16=250
Blue E216=226
Can someone tell me how that answer is given?
Write the first four terms of the following sequences?
(i) an=4nsquared -2, n more than or equal to 1
(ii)an=6an-1 + 1,n more than or equal to 1 where a1 = 5
(b)
The first term of the geometric sequence is 12.5 and the common ratio is 0.4
(i) Write out the first four terms of the sequence
(ii)Write out the formula for the nth term of this sequence
(iii)What is the 12th term of this sequence?
(iv)Write out the formula for the sum of the first n terms of this sequence.
(v)What is the sum of the first 8 te
This isn't too difficult. Base 16 means you have values in the range 0-15, each of which is represented as a single digit. After 9, we'd have to use two digits to represent the numbers, so we use letters instead (starting with A). Can you now work out what D is?
Edit: Your questions seem to be quite distinct, so you should probably be using separate threads for each..
nylex said:
this isn't too difficult. Base 16 means you have values in the range 0-15, each of which is represented as a single digit. After 9, we'd have to use two digits to represent the numbers, so we use letters instead (starting with a). Can you now work out what d is?
a=10
b=11
c=12
d=13
e=14
f=15
Yes, that's correct.
so for example is i was given
1FF2 = it would be 11515216
I don't suppose you know how to solve the rest of the problems?
I'm not exactly sure what you mean by "11515216". You know that each digit represents a multiple of a power of the base, yes? For example, in decimal (base 10),
\begin{equation}
123 = 1 \times 10^2 + 2 \times 10^1 + 3 \times 10^0
\end{equation}
You're going to need to show evidence of what you've tried already and what you don't understand. The first question seems to give you the relation between the nth term and n, so it shouldn't be too hard. Presumably, you've also seen a geometric series before.
