Matrix problem help. solve the remaining equation and find the value(s) for x
  • Thread starter Thread starter flatty
    Matrix
The forum discussion revolves around solving a matrix equation represented as | x 0 c| | -1 x b| = 0 | 0 -1 a|. The key takeaway is that the determinant of the matrix must equal zero, leading to a quadratic equation of the form Ax^2 + Bx + C = 0. The solution for x can be derived using the quadratic formula x = [-b ± √(b^2 - 4ac)]/2a, where a, b, and c are coefficients derived from the matrix elements. Numerical values for x can only be obtained if specific values for a, b, and c are provided.
  • Understanding of matrix determinants
  • Familiarity with quadratic equations
  • Knowledge of the quadratic formula
  • Basic algebra skills
  • Study matrix determinant calculations in linear algebra
  • Explore the derivation and application of the quadratic formula
  • Learn about solving systems of equations using matrices
  • Investigate numerical methods for approximating solutions when variables are unknown
This discussion is beneficial for students studying linear algebra, particularly those tackling matrix equations and quadratic formulas. It is also useful for educators looking for examples of matrix determinant applications in problem-solving.
flatty
| x 0 c|
| -1 x b| = 0
| 0 -1 a|
As best as I can tell I would end up with x * (xa - (-1b)) and -1c and then I would end up with Ax^2 + BX + C which leaves me confused am I looking at a quadratic equation for the answer or is there a way to get numerical values out of it?
flatty said:
| x 0 c|
| -1 x b| = 0
| 0 -1 a|
Your problem statement says that the determinant of your matrix is zero.
What equation represents this?
I presume you are taking the determinant and setting it equal to zero. If so, what you've done looks right. Remember the solution to a quadratic equation? Also, you can only get a numerical answer if you know the values of a,b,c. Otherwise, the answer will be an expression involving a,b,c.
0=x*(xa-(-1b))-(-1*c)
I am using det(a)=A11(A22*A33-A23*A32)-A12(A21*A33-A23*A31)+A13(A21*A32-A22*A31)
Yes it is equal to zero sorry, new here.
Ax^2+bx+c=0 so I am assuming my answer would be x = [-b ± √(b^2 - 4ac) ]/2a
thanks
