No problem, glad I could help! :smile:
  • Thread starter Thread starter Temp0
    Matrix Unknowns
The discussion focuses on solving a system of equations to determine conditions for no solution, one solution, and infinitely many solutions. The user successfully reduced the equations into matrix form but initially struggled with finding the unique solution and understanding the concept of infinite solutions. Clarifications were provided regarding the conditions for no solution (when ab = 2) and hints were given to help understand infinite solutions. Ultimately, the user resolved their confusion about the unique solution after further review. The conversation emphasizes the importance of matrix reduction in solving linear equations.
Temp0
In the following problem, find conditions on a and b such that the system has no solution, one solution, and infinitely many solutions.
x + by = -1
ax + 2y = 5
None that I know of.
Basically, first I put the entire equation into a matrix.
[ 1 b | -1
a 2 | 5 ]
I reduce the bottom by subtracting R2 - aR1
[ 1 b | -1
0 2-ab| 5 +a ]
I then reduce the bottom again by dividing R2/(2-ab)
[ 1 b | -1
0 1 | (5+a)/(2-ab)]
I remove the b from the top by subtraction: R1 - bR2
[1 0 | -1 - b((5+a)/(2-ab))
0 1 | (5+a)/(2-ab) ]
This leaves me with the values for x and y, and for the first question I am correct in saying if ab = 2, then there is no solution as it is undefined. However, my unique solution is somehow wrong and I would like some help in determining if I made an error or I somehow didn't reduce something.
The correct unique solution is: x = (-2 - 5b)/(2-ab) y = (a+5)/(2-ab)
Also, I have no idea what finding an infinite solution means, I would really like some help on clarifying that. Thank you.
Hi Temp0! Welcome to PF! :smile:
That is the same as yours! :wink:
Hint: if A and B are two solutions, what can you say about A - B ? :smile:
For example: if you are given graphs of f(x) and g(x) [neither contain discontinuities] and g(x) 's graph never "falls under" or crosses f(x) , no matter what the argument, g(x) has always higher values than f(x) and you are asked to provide solutions for g(x) > f(x) then you can say that there are infinitely many solutions. But you are dealing with an equal sign so that must mean the 2 graphs are...?
tiny-tim said:
Hi Temp0! Welcome to PF! :smile:That is the same as yours! :wink:Hint: if A and B are two solutions, what can you say about A - B ? :smile:
Hmm, thanks for the help on the infinite thing, I finally get that ^^. However, I've tried reducing and expanding my answer, but it never becomes the same as the answer in the book. Are there any hints you can give me? =D
edit: nvm, I just looked at it again and realized how to get to the answer, thanks for your help =p.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
