Maximize volume of a rectangular box
The discussion focuses on maximizing the volume of a rectangular box with one vertex constrained to the plane defined by the equation x + y + 4z = 4. The volume is expressed as V = (4-x)(4-y)(1-z), leading to a maximum volume of 16/27 when x and y are both equal to 4/3 and z is 2/3. The use of Lagrange multipliers is essential for solving this optimization problem, ensuring that the constraints imposed by the plane are respected while maximizing the volume.
  • Understanding of Lagrange multipliers for constrained optimization
  • Familiarity with the geometry of planes in three-dimensional space
  • Knowledge of partial derivatives and their application in optimization problems
  • Basic algebra for manipulating equations and solving for variables
  • Study the application of Lagrange multipliers in various optimization scenarios
  • Explore the geometric interpretation of constraints in optimization problems
  • Learn about the derivation and application of volume formulas for three-dimensional shapes
  • Investigate other methods for solving optimization problems, such as the method of substitution
Students and professionals in mathematics, engineering, and physics who are dealing with optimization problems involving constraints, particularly in three-dimensional geometry.
theno1katzman
Find the volume of the largest rectangular box in the first octant with three faces in the coordinate planes and one vertex in the plane x + y + 4z = 4
Volume of a box with L being the length of a diagonal in that box = L3/(3sqrt3)
Shortest distance from any point (x,y,z) to a plane with normal vector [a,b,c]
abs(ax+by+cz+d)/(sqrt(a2+b2+c2))
L = distance from (0,0,0) to plane x +y+4z=4
= abs(-4)/sqrt(18)
= 4/(3sqrt2)
V= (4/(3sqrt2))3/(3sqrt3)
= 32/81sqrt6
Now I realized that what I did here that was wrong was I assumed that the shortest distance to the plane was that diagonal. But it doesn't have to be, or does it?
Is there only one way that the box can have a vertex on that plane? I figured that you can change the shape of the box and a vertex will hit the plane somewhere else.
Thanks for your help.
= abs(-4)/sqrt(18)
= 4/(3sqrt2)
= 32/81sqrt6
Nope. Minimizing L would minimize V whereas you want to maximize the volume. Also, does that formula you're using apply to rectangular boxes in general or to just a cube? (I don't know, but I suspect it's just a cube.)
Right, the shape of the box is subject only to the constraint that the vertex lies somewhere on the specified plane.
This problem is one of maximizing a function subject to a constraint, which suggests you use Lagrange multipliers.
Ok here is the problem worked out again.
The vertex on the box that is located on the plane can be found by the graph if you were to draw this situation.
pt (4-x,4-y,1-z) using simple geometry.
Now the distance from the origin to this point is going to be the diagonal of this box, cube the diagonal and divide by 3\sqrt{3} and you will get the volume.
Vx=\lambdagx
Vy=\lambdagy
Vz=\lambdagz
Taking those partial derivatives you will get 3 equations using the multipliers to tie them to each other, you get
16(x-4)2=16(y-4)2=(z-1)2
x=y so 16(x-4)2=(z-1)2
or 4(x-4)=(z-1) solving for z you will get z=4x-15
now I was told to use the constraint of the equation of the plane to figure out x, y and z, because I don't know how to find the values of them otherwise.
placing z and y in terms of x in the constraint
x + y + 4z = 4
yields
x + x + 4x -60 =4
and x = 32/9
y= 32/9
and z = 7/9
(z was actually -7/9 but I took the opposite of it because it can't be negative, this is the part of the problem that you may have a problem with)
and your answer for volume, multiply them together and you will get
about 9.83
Your explanation unfortunately omits a lot of details. I can't figure out what you did.
What is this?
Vx=\lambdagx
Vy=\lambdagy
Vz=\lambdagz
What are the V's and the g's?
How did you get this?
x + y + 4z = 4
yields
x + x + 4x -60 =4
and x = 32/9
y= 32/9
and z = 7/9
about 9.83
Ok there is another way to get the volume of that box. The volume is going to be V=lwh. Length of the box is going to be 4-x. Width 4-y. And height 1-z.
V= (4-x)(4-y)(z-1)
= 16z-4xz-4yz +xyz-16+4x +4y -xy
The three partial derivatives set equal to zero
Vx =-4z +yz+4-y = 0
Vy =-4z +xz +4 -x =0
Vz = 16- 4x -4y +xy =0
If you use lagrange multipliers you can tie the equations together.
Like I said before,
lambda*gx = Vx
lambda = -4z +yz+4-y
(remember g(x,y,z) was x+y+4z=4)
lambda*gy = Vy
lambda =-4z +xz +4 -x
lambda*gz = Vz
4*lambda =16- 4x -4y +xy
Now the first two can be set equal to each other because they both equal lambda.
-4z +yz+4-y = -4z +xz +4 -x
This simplifies to x=y
Using that known information in Vz
16- 4x -4x +x2 = 4lambda=4(-4z +xz +4 -x)
This simplifies to
x2-4x+16z-4xz=0
But from the constraint equation of the plane x + y+ 4z=4
2x+4z=4 because x=y at that point
x+2z=2 divide by 2
x=2-2z
Plug that into above equation.
x2-4x+16z-4xz=0
now becomes
(2-2z)2-4(2-2z)+16z-4(2-2z)z=0
simplifies to 12z2-8z-4=0
factors to 4(3z-1)(z+1)=0
z=1/3
plug this back into constraint equation knowing that x=y
2x+4(1/3)=4
x=y=4/3
Volume of box = (4/3)(4/3)(1/3)=16/27
You're being inconsistent. Here you said:
V= (4-x)(4-y)(z-1)
I'm not sure how you came up with 4-x, 4-y, and 1-z as the lengths of the sides, and then you flipped the sign of 1-z when you plugged it into formula for the volume.
Finally, at the end, you say:
z=1/3
2x+4(1/3)=4
x=y=4/3
So now you're saying V isn't (4-x)(4-y)(1-z) nor (4-x)(4-y)(z-1), but xyz.
I'm going to go back and fix those silly errors but other than that I presume the calculus to be correct?
The lengths of the sides of the rectangular box come from geometry and looking at the object. If you draw that plane x +y+4z=4 it intersects the y-axis at (0,4,0) and that gives the length from the origin to the point 4. I split the length into y and 4-y where 4-y is the length of the side of the box. I did this rather than just saying that the length was y.
The width would be the same deal, using the x values, and would be 4-x.
The height would be found the same way, 1-z.
The points on the edges of that box that lie on the coordinate axes are as follows.
For the y axis, the point (0,4-y,0)
x axis (4-x,0,0) and z axis (0,0,1-x). Now that would make the vertex that lies on the plane (4-x,4-y,1-z)
The volume of that box is the (4-x)(4-y)(1-z) because of the distance from (0,4-y,0) to (0,0,0) is 4-y,
distance from (4-x,0,0) to (0,0,0) is 4-x,
distance from (0,0,1-x) to (0,0,0) is 1-z.
So what you did was define new variables x', y', and z' such that x=4-x', y=4-y', and z=1-z'. Then V=xyz=(4-x')(4-y')(1-z'). You need to express g(x,y,z) in terms of the new variables, however, if you want to use this approach. Or you could just use V=xyz and redo your calculations.
If V=xyz and g(x,y,z) = x +y + 4z =4 Then to maximize the volume of the box, you would use three partial derivatives tied to each by the Lagrange multipliers.
Vx= lambda*gx
yz= lambda
Vy= lambda*gy
xz= lambda
Vz= lambda*gz
xy= lambda*4
yz=xz
y=x
and xy = 4yz
x2=4xz
x=4z
then, x + y + 4z =4 becomes 4z + 4z + 4z = 4
z = 1/3
then x = 4/3 and y=4/3.
This will give the volume of the box to be 16/27.
Now if I used the point (4-x,4-y,1-z).
I get equation for volume
V=(4-x)(4-y)(1-x) and equation for plane (4-x)+(4-y)+4(1-z)=4
which simplifies to x + y+ 4z = 8
Vx= lambda*gx
-4 +y+4z-yz= lambda
Vy= lambda*gy
-4 +x+4z-xz= lambda
Vz= lambda*gz
-16 +4x+4y-xy= lambda*4
Setting the first equation to the second will show that y=x like before.
Setting the third equation equal to four times the first will show that
16z-4xz-4x+x2=0
From the equation of the plane x+y+4z=8 (remember it changed from using the new point (4-x,4-y,1-z))
x=4-2z
Plug this into the above equation.
16z-4(4-2z)z-4(4-2z)+(4-2z)2=0
solving this for z
12z2-8z=0
4z(3z-2)=0
z=0 which can't be true. and z=2/3
now solving for x and y
x=4-2(2/3)
x=8/3
y=8/3
And then the volume (4-8/3)(4-8/3)(1-2/3) = 16/27
Now are we done? The volume was what they asked for. Did this maximize it?
Yup, you're done.
15K
29K
13K
