Maximizing Angle Theta on a Line AB: Calculus Assignment Help
8 replies · 2K views
Greetings! Is your answer supposed to be in terms of the length of AB?
yes! sorry i forgot to mention that up there =)
In that case, try extending a horizontal line from point P in order to split up θ into two angles, θ1 and θ2, such that θ = θ1 + θ2. Call x an unknown length starting at point P and going upwards along AB. Check out the bottom-most angle on the right. Call it φ, and note that θ1 (the lower part of θ) is
[tex]\theta_1 = \varphi = \arctan(\frac{3+x}{5})[/tex]
because φ and θ1 are alternate interior angles. Try deriving a similar expression for θ2, keeping in mind that this part will depend on AB.
alright so will this work?: θ = θ1 + θ2
tan θ1=BP/BC (where C= the angle between B and P)
θ1=arctan(BP/BC)
tan θ2=AP/AD (where D= the angle between A and P)
θ2=arctan(AP/AD)
sum= θ1 + θ2 --> arctan(BP/BC)+arctan(AP/AD)
then add in the known values:
θ1 + θ2= arctan(BP/2)+arctan(AP/5)
θ= arctan((1/2)BP)+arctan((1/5)AP)
since we know AP+BP=3...solve for BP.
BP=-AP+3 and then substitute into the equation above:
θ= arctan((1/2)(-AP+3))+arctan((1/5)AP)
θ= -arctan((1/2AP-3/2))+arctan((1/5)AP)...then found the derivative
y= -1/(2(1+(1/2)AP-(3/2))^2) + 1/(5(1+(1/25)AP)^2)
i then solved for AP
and got 5+2sqrt(5)=9.472
and 5-2sqrt(5)=.5279
and my answer was .5279
is that correct?
Was it given in the problem that AP+BP = 3? Just looking at the image, it seems that we only know that AP is currently length 3.
yes, but in my image on my sheet, AP AND BP total is 3.
so based on that, would what i did be correct?
If this is true, then your result seems fine to me. Good work!
