Maximizing Diffraction of Water Waves through a Single-Slit Barrier
Increasing the depth of water in the tank enhances the wavelength of the waves, which in turn increases the degree of diffraction. Making the water deeper on only one side of the barrier may create a difference in wave behavior, but its specific impact on diffraction is less clear. The discussion emphasizes that diffraction is influenced by wavelength, with longer wavelengths resulting in greater diffraction. Observers are encouraged to consider the wave dynamics immediately after passing through the slit, focusing on aspects like frequency, amplitude, and wavelength. Overall, understanding how water depth affects wave properties is crucial for maximizing diffraction.
Deathnote777
Suppose a water wave is moving from left to right in a water tank. The water tank is divided to two region (left and right) by an one-slit plastic plate. Which of the following(s) adjustment can increase the degree of diffraction of the wave ?
(1) Make the water of the whole tank deeper.
(2) Make the water in the right side deeper only.
(3) Make the water in the left side deeper only.
Nil
I know (1) must be correct as it can increase wavelength. But I am not sure whether (2) and (3) is correct or not, please explain. Thanks
Imagine you're a bit of the water just past the slit. Over time, what are you aware of wrt the movement of the water in the first half of the tank?
As far as I know, wavelength in deeper region will be longer. My teacher told me that the degree of diffraction will increase with the wavelength of waves. However, I don't know what will happen when making only 1 side deeper while another side remains unchanged.
you are right about the wavelength in deeper water being longer.
Yes, I understand that. Did you try to answer my question?
I don't really understand your question exactly. If I am a bit of the water and am passing through the slit, I will be diffracted, move away from the central line after passing through the slit
No, you're not passing through the slit, you're sitting on the surface just after the slit. (The wave moves, not the water.). What can you determine about the wave?
The wave will diffract
No, you're thinking like an external observer able to see the whole thing. I'm asking you to be a microscopic observer only able to see what's going on immediately after the slit. What do you experience? What can you tell about the wave wrt frequency, amplitude and wavelength?
