Maximizing f(x) with Inequality Constraint: Solving a Functional Inequation
  • Thread starter Thread starter utkarshakash
    Functional
9 replies · 2K views
utkarshakash
The function f satisfies [itex]\dfrac{f(x)}{f(y)} \leq 2^{(x-y)^2} x,y \in D[/itex] where D denotes domain set of the function, then f(x) can be
I have a set of options as well but I'm not posting it now. I will post it if required, later.
I have dealt with functional equations but this seems more daunting as it is rather an inequation. First, to simplify it, I take natural logarithm of both sides. Then
[itex]log f(x) - logf(y) \leq (x-y)^2 log2[/itex]
My next thought is to differentiate the expression wrt x. But I'm not sure whether it would be helpful as I don't want to do it uselessly.
"Can be", rather than "is", suggests that checking which of those options satisfies this condition is the way forward.
So how should I check the given options?
Calculate [itex]f(x)/f(y)[/itex] for each case, and check whether the result is less than or equal to [itex]2^{(x-y)^2}[/itex].
One other thing is that, since (x - y)2 ≥ 0 for any real x and y, it must be true that f(x)/f(y) ≥ 20 = 1. You didn't show what the options are, but if there are any that are less than 1, you can eliminate them from further consideration.
Edit: Never mind on the above. I was looking at the wrong direction of the inequality in post #1.
BTW, we don't call it an "inequation" - we call it an inequality.
I'm not sure how that follows from [itex]\dfrac{f(x)}{f(y)} \leq 2^{(x-y)^2}[/itex].
For example, one option is
[itex]\int_0^x 2t^3 dt[/itex]
This function is x^4/2. You are saying to simply plug x in one and y in another. Doing that gives
[itex]\left( \dfrac{x}{y} \right) ^4[/itex]
Now how do I check whether this is less than [itex]2^{(x-y)^2}[/itex] or not? Should I start substituting some random values?
You don't say what D is. Is it specified separately for each f option?
Since the right-hand side of the inequation becomes weak when x and y are far apart, and the inequation is trivially true when x = y, I would concentrate on y and x differing by a small amount.
You can look at the function
[tex]F(x,y) = \left(\frac{x}{y}\right)^4 - 2^{(x-y)^2},[/tex]
and try to maximize it, to see if its maximum is ≤ 0.
