Maximizing Fluid Storage in a Rectangular Tank with Given Force Limit
The discussion revolves around a problem involving fluid storage in a rectangular tank, specifically focusing on maximizing the volume of fluid that can be stored given a maximum force limit on the tank's walls. The subject area includes fluid mechanics and calculus, particularly in relation to pressure and force calculations within a liquid context.
  • Participants discuss the setup of the problem, including the integration of force and pressure over the tank's walls. Questions arise regarding the definition of fluid force and how to approach the integration for volume calculation. Some participants suggest defining pressure in relation to depth and integrating over the area of the tank's walls.
The discussion is ongoing, with participants exploring different interpretations of fluid force and pressure. Some guidance has been offered regarding the use of pressure equations and integration techniques, but there is no explicit consensus on the approach to take.
Participants are working under the constraints of a homework assignment, which may impose specific methods or equations that need to be utilized. There is also a noted uncertainty regarding the definitions and terms related to fluid mechanics, such as fluid force and pressure.
liberty/death
This is just a general question.
The questions I can't get go something like this:
You're given a liquid you plan to store, in a tank, say for this example, a rectangular one with square sides. You're given the max fluid force that the interior walls can withstand, and asked to find how many cubic units of fluid the tank can store, at maximum, I'm assuming.
My question is, how do you go about setting up a problem like this in general?
So far I've tried to setup the integral with the force already put in (since its given), but I don't know where to start with how to integrate / solve for volume / find boundaries / etc.
Any help or hints would be appreciated.
start by defining the pressure on a face with depth for a given height h, then intergate over the area of a face to find the force
By pressure, are you referring to the fluid force? If so, how would you even go about doing that? As the surface of the fluid is not defined.
what do you mean by fluid force? I'm not really familiar with the term..
By pressure I mean force per unit area
[tex]P = \frac{F}{A}[/tex]
the pressure in a liquid at depth h will be given by:
[tex]P = \rho g h[/tex]
Well, this is suppose to be a fluid force problem, though there are many ways to solve it I'm sure. We're suppose to make use of the fluid force equations. Namely:
F=whA and F= the integral of w(strip depth) L(y) dy.
w= weight density of liquid
L(y)=length of strip
A=area
ok yep
  • · Replies 77 ·
15K
  • · Replies 18 ·
13K
10K
