Maximum entropy implies linear expansion?
The discussion explores the implications of maximum entropy in an expanding sphere containing mass, M, and its relationship to black hole formation. It references the Bekenstein bound, suggesting that maximum entropy is achieved when the sphere's mass increases with its radius, R, leading to continuous matter creation. The derivation of the Friedmann equation indicates that the expansion of the universe can be modeled linearly, with the scale factor a(t) proportional to time. The conversation also touches on the nature of matter at the edge of the observable universe and the potential for Hawking radiation, concluding that the expanding sphere may not radiate outward due to the receding horizon. This model proposes that the radius of the spherical horizon increases with cosmological time, aligning with current observations.
johne1618
Imagine we are at the center of a sphere of radius R containing a mass M.
The Beckenstein bound states that the entropy inside that sphere, S, must be given by the inequality:
\large S \leq \frac{2 \pi k c R M}{\hbar}.
In order to maximise the entropy we need to fill the sphere of radius R with as much mass M as possible. The limit is reached when we have created a black hole. This occurs when the following relationship holds:
\large \frac{G M}{R} = \frac{c^2}{2}. \ \ \ \ \ \ \ \ \ \ (1)
Now in the case of a black hole the event horizon is at a constant radius R and we are sitting on the singularity at the center.
But instead let us assume that the sphere is expanding.
Let us also assume that Equation (1) always holds so that the expanding sphere always has a maximum entropy. This of course means that the mass M must increase with radius R. Thus matter is being continuously created.
If we assume flat space then Equation (1) implies that the mass density, \rho, is given by
\large \rho = \frac{3 c^2}{8 \pi G R^2}. \ \ \ \ \ \ \ \ (2)
If we assume that the radius R(t) is expanding with the Universal scale factor a(t) then we can say:
R(t) = R_0 a(t) \ \ \ \ \ \ \ \ (3)
where t is the cosmological time, R_0 is the radius at the present time t_0 and a(t_0) = 1.
Now let us consider the Friedmann equation for flat space with no cosmological constant:
\large (\frac{\dot{a}}{a})^2 = \frac{8 \pi G}{3} \rho \ \ \ \ \ (4)
Substituting Equations (2) and (3) into Equation (4) we obtain
\large (\frac{\dot{a}}{a})^2 = \frac{c^2}{R_0^2 a^2}.
As the Hubble parameter at the present time, H_0, is given by
H_0 = c / R_0,
we finally arrive at
\large (\frac{\dot{a}}{a})^2 = \frac{H_0^2}{a^2},
which has the simple linear solution
a = H_0 t.
This solution to the Friedmann equation is thus the maximum entropy solution.
It is very close to what is observed.
Space news on Phys.org
Where is this matter being created? At the edge of our observable universe? What's creating it?
If it's at the edge of our Observable Universe, it may mean it's not created but simply enters our Observable Universe as its edge is moving further away.
Just a thought, I might be wrong.
That is my understanding of how it works, not that it is being created.
The maximum entropy condition for the expanding sphere can also be written as
\large S = \frac{k A}{4}
where A is the surface area of the sphere in units of Planck area \hbar G / c^3.
Thus, following the Holographic principle, we can think of all the entropy of the sphere as residing on its surface.
Now we also have the following thermodynamic relationship between the change in the mass/energy of the system and the change in its entropy
\large dM = \frac{T}{c^2} dS,
where T is the Unruh temperature at the surface of the sphere due to the gravity of the mass inside it.
This shows that the mass change of the expanding sphere occurs due to the increase of the entropy in its expanding surface area.
The horizon radiates Hawking radiation, but I guess the universe is way too big to be kept in balance by this -- it might be a fun exercise to check if there exists some radius where this is true. If I remember correctly, the radiation power depends on M like ~M^-2, so there might be a "sweet spot".
In this model the radius of the spherical horizon R increases with cosmological time t according to the formula:
R = c t.
I presume that the expanding sphere will not radiate Hawking radiation outside itself as the radiation could not "outrun" the receeding horizon.
R = c t.
It's a borderline case, but maybe if ct is slightly larger than R, the horizon starts radiating causing you to expand slower and pushing you towards ct -> R.
  • · Replies 27 ·
