How Do You Compute the MLE for p in a Treatment Effectiveness Study?
The discussion focuses on computing the maximum likelihood estimate (MLE) for the proportion killed by a treatment in a study involving patient survival rates. Participants are working through the likelihood function derived from the distribution of the number of survivors, P(N=n)=(n+1)(1-p)n p^2, and are attempting to formulate the MLE for p. The conversation includes clarifications on handling terms in the likelihood function and emphasizes the importance of simplifying the expression to find the maximum. The process involves taking the logarithm of the likelihood function, differentiating it, and setting the derivative to zero to solve for p. The discussion highlights common pitfalls in differentiation and the significance of correctly applying the logarithmic properties.
ianrice
1. An experiment consists of giving a sequences of patients a risky treatment until two have died, and then recording N, the number who survived. If p is the proportion killed by the treatment, then the distribution of N is:
P(N=n)=(n+1)(1-p)n p2
1)Find a general formula for the MLE for p:
2)the experiment is done in 8 hospitals and the observed values of N are 3,0,4,2,3,5,1,3. Compute the estimate for the p derived in part 1
2. I know I have to start by finding a general form of ∏(ni+1)(1-p)ni p2 with ni where i goes from 1 to m.
3. So I get hung up on how to handle the (ni+1) term.
What is preventing you from computing P(N1=3,N2=0,N3=4,...,N8=3)?
The question asks for the general form of the MLE of p. then to compute P(N1,N2...N8). I need help with the general form
There's a typo in your post. Witness that hanging .
I suspect you meant ##\Pi_{i=1}^m (n_i+1)(1-p)^{n_i} p^2##
This isn't that hard. Let's start with m=1, i.e., one observation. Then that product is simply ##(n_1+1)(1-p)^{n_1}p^2##. With m=2, the product becomes ##(n_1+1)(1-p)^{n_1}p^2\,(n_2+1)(1-p)^{n_2}p^2##. Try collecting terms. You should get something of the form ##A (1-p)^B p^C##, where A, B, and C are related to the observed values. Now generalize to m observations.
Where does this reach a maximum?
Start with simple cases, by writing the formula for the likelihood function of P(n1,n2) and maybe P(n1,n2,n3). This will show you the pattern that applies as well to larger problems.
So I've collected terms for m=3 and get the following:
(n1+1)(n2+1)(n3+1)(1-p)n1(1-p)n2(1-p)n3p2p2p2
So by using your A(1-p)BpC:
I think B=∑ni
C=2n
A is where I'm still stuck. Am I missing something completely I can't seem to figure out how to reduced (n1+1)(n2+1)(n3+1)
And to find the maximum I need to set the derivative to 0 and find p the parameter the question ask for.
What are ##(1-p)^{n_1}(1-p)^{n_2}(1-p)^{n_3}## and ##p^2p^2p^2##? Surely you can reduce these to a simpler form!
I got those:
##(1-p)^{n_1}(1-p)^{n_2}(1-p)^{n_3}## = (1-p)∑ni
##p^2p^2p^2## = p2n
I think B=∑ni
C=2n
Why would you care about reducing ##(n_1+1) (n_2+1) \cdots (n_m+1)##? It has no effect whatsoever on the optimal value of p. In other words, the p that maximizes f(p) is the same p that maximizes 1000*f(p) or (1/100)*f(p) or any K*f(p) for constant K.
Ok right I understand. I was confused.
So am I correct with the following next steps:
L(p)= ∏(ni+1)(1-p)∑nip2n
Then in the next take is to find l(p) which is l(p)=Ln(L(p))
So I end up with:
l(p)= Ln(∏(ni+1))+∑niLn(1-p)+2n*Ln(p)
Then taking the derivative of dl(p)/dp and setting that to zer
dl(p)/dp= 0+ \frac{∑n}{1-p} +\frac{2n}{p}
So I end up with:
Almost OK, but ##d \ln(1-p) /dp = -1/(1-p)##, not ##+1/(1-p)##. The thing you wrote could never = 0 for any p between 0 and 1.
