Maximum position expectation value for 1D harmonic oscillator
The discussion focuses on maximizing the expectation value \(\langle x \rangle\) for a linear combination of states \(|0\rangle\) and \(|1\rangle\) in a one-dimensional harmonic oscillator. The participants utilize the Lagrange multiplier method to derive coefficients \(c_1\) and \(c_2\) that maximize the expectation value under the normalization constraint \(c_1^*c_1 + c_2^*c_2 = 1\). The final solutions yield multiple valid sets of coefficients, differing only by a phase factor, confirming the inherent freedom in quantum state representation.
  • Understanding of quantum mechanics, specifically harmonic oscillators
  • Familiarity with expectation values in quantum states
  • Knowledge of Lagrange multipliers for optimization problems
  • Basic concepts of quantum state normalization
  • Study the application of Lagrange multipliers in quantum mechanics
  • Explore the properties of quantum states and their phase factors
  • Learn about expectation values in quantum mechanics, focusing on harmonic oscillators
  • Investigate the implications of state normalization in quantum systems
Students and researchers in quantum mechanics, particularly those working on harmonic oscillators and optimization problems in quantum states.
AwesomeTrains
Hey, I'm stuck halfway through the solution it seems. I could use some tips on how to continue.
1. Homework Statement
I have to determine a linear combination of the states |0\rangle, |1\rangle, of a one dimensional harmonic oscillator, so that the expectation value \langle x \rangle is a maximum.
x=\sqrt{\frac{\hbar}{2m\omega}}(a+a^\dagger)
I set |\alpha \rangle\equiv c_1|1\rangle + c_2|0\rangle
Then I calculate \langle \alpha | x | \alpha \rangle = \sqrt{\frac{\hbar}{2m\omega}} (c_1^*\langle1| + c_2^*\langle 0|)(a+a^\dagger)(c_1|1\rangle + c_2|0\rangle)=\sqrt{\frac{\hbar}{2m\omega}}[c_1^*(c_1+c_2)+c_2^*c_2] = \sqrt{\frac{\hbar}{2m\omega}}[1+c_1^*c_2]
I get the last equation because of the normalization condition:
c_1^*c_1+c_2^*c_2=1
This is where I don't know how to continue. Is this even the right approach?
(I'm not allowed to use the wave functions.)
Anything is appreciated.
Kind regards
Alex
You should recheck your calculation of ##\langle \alpha \lvert x \rvert \alpha \rangle##. The ##c_i^*c_i## terms shouldn't be there.
As for the maximization problem, the Lagrange multiplier method may be helpful.
Thanks for the fast reply.
I've corrected my calculation, is this right?:
First I calculate (a+a^\dagger)|\alpha\rangle
a(c_1|1\rangle+c_2|0\rangle)=c_1|0\rangle+0c_2|0\rangle=c_1|0\rangle
and
a^\dagger(c_1|1\rangle+c_2|0\rangle)=c_1\sqrt{2}|2\rangle+c_2|1\rangle
Then because |\alpha\rangle^\dagger = c_1^*\langle1|+c_2^*\langle0|
\langle\alpha|(a+a^\dagger)|\alpha\rangle=c_1^*\langle1|(c_1\sqrt{2}|2\rangle+c_2|1\rangle+c_1|0\rangle)+c_2^*\langle0|(c_1\sqrt{2}|2\rangle+c_2|1\rangle+c_1|0\rangle)= c_1^*c_2+c_2^*c_1
Do I use the lagrange multiplier method here? Or how do I continue?
The Lagrange multiplier is used for finding the maximum value of <x>.
So It's like a function of 4 variables f(c_1,c_1^*, c_2,c_2^*)=c_1^*c_2+c_2^*c_1 which I have to maximize under the condition c_1^*c_1+c_2^*c_2=1
Or is there an easier solution?
Hello! I Have the same exercise in my homework. Using the Lagrange multiplier I get ##c_{1}=c_{2}=1/\sqrt{2}##. Is that right?
Yes, it is.
Whether it's true or not, you can do some kind of examination. For example, you can write ##\langle \hat{x} \rangle \propto |c_1||c_2| \cos{(\phi_1-\phi_2)}## where the ##\phi##'s are the angle of each coefficients, since we want to maximize our expectation value, it's necessary that ##\phi_1=\phi_2##.
Thanks for advise, blue_leaf77. I have made my calculation new.
I get 4 different sets of values.
##c_{1}=c_{2} = i/\sqrt{2}##
##c_{1}=c_{2} = -i/\sqrt{2}##
##c_{1}=i/\sqrt{2}; c_{2} = -i/\sqrt{2}##
##c_{1}=-i/\sqrt{2}; c_{2} = i/\sqrt{2}##
Using your advise how to examine solutions only the first and the second solutions are of interest. I can get this result on another way just inserting values in ##f## and finding a maximum. My question is: how i decide which set is right (the first or the second)?
Well as long as ##\phi_1 = \phi_2## is satisfied, any ##\phi_1## is possible.
In the original question posted by the OP, he is asked to calculate the maximum of ##\langle \hat{x} \rangle##. In your case, I don't know what you are asked to do in your own homework.
I have to calculate the maximum of ##\langle \hat{x} \rangle## too
You have this freedom.
Your first solution corresponds to the state
$$\lvert \alpha_1 \rangle = i\left(\frac {1}{\sqrt{2}} \lvert 0 \rangle + \frac{1}{\sqrt{2}} \lvert 1 \rangle\right) = e^{i\frac {\pi}{2}}\left(\frac {1}{\sqrt{2}} \lvert 0 \rangle + \frac{1}{\sqrt{2}} \lvert 1 \rangle\right),$$ and your second solution to
$$\lvert \alpha_2 \rangle = -i\left(\frac {1}{\sqrt{2}} \lvert 0 \rangle + \frac{1}{\sqrt{2}} \lvert 1 \rangle\right) = e^{-i\frac {\pi}{2}}\left(\frac {1}{\sqrt{2}} \lvert 0 \rangle + \frac{1}{\sqrt{2}} \lvert 1 \rangle\right).$$ The two states differ only by an overall phase factor, so…
  • · Replies 0 ·
  • · Replies 16 ·
