Maximum Source Resistance for Optimal ADC Performance
  • Thread starter Thread starter MrBondx
    Adc Input Noise
9 replies · 4K views
MrBondx
A simplified model of ADC noise refers the noise to a noisy source resistance Rn while assuming the rest of the signal path to be noiseless. Figure 3 represents a particular 18-bit ADC that has a 10 V input voltage range. The ADC has a bandwidth of 1 MHz.
Calculate the maximum value of Rn if the resolution of the ADC is not to be adversely affected by thermal noise. Assume the ADC operates at 25 degrees C.
[N.b. The voltage resolution of an ADC is equal to its overall voltage measurement range divided by the number of discrete values possible on its output.]
FIG. 3
[/B]
The issue of resolution has totally thrown me off but here is what I'm thinking.
Rn = (Vn \ 4kTRB), where k is the Boltzmann constant.
Vn = ? I'm not sure whether Vn = resolution or full scale voltage.
It's all I got for now, please help!
MrBondx said:
Rn = (Vn \ 4kTRB)
That equation does not look correct. What is the equation for the thermal noise voltage in terms of of k and T and R and B?
Thanks, Yea my mistake
Vn = sqrt(4kTBR)
Re-arranging
R = (Vn^2 / 4kTB)
Vn = sqrt(4kTBR)
Re-arranging
R = (Vn^2 / 4kTB)
Ah, much better. I was getting vertigo trying to decipher what you wrote. :smile:
So now you're pretty much done. Take the input voltage range and divide by the total resolution (18 bits is how many steps?). Then apply the formula...
:smile:
Input voltage resolution
18bits = 2^18 steps = 262144
Voltage range / steps = (10 / 262144)
Vn = 38.14697 x 10^-6 V
Is that correct?
MrBondx said:
:smile:
Is that correct?
Yes, I get 38.15uV as well. So what is the equivalent resistance to make that noise voltage at (absolute) room temperature?
Converting Celsius to Kelvin
25degrees = 298.15 K
Plugging numbers into equation
Rn = (38.15 x 10^-6)^2 / (4 x (1.38 x 10^-23) x 298.15 x 1000000)
= 88433.17
Rn = 88.4 kOhms
= 88433.17
Rn = 88.4 kOhms
Looks like a reasonable value. Do you know if it's correct?
I hope it is correct, will send it for marking. Thanks for your help, much appreciated.
