Maximum speed of a string help
The discussion focuses on calculating the maximum speed of a transverse wave on a string described by the equation y(x,t)=0.044 sin(4.20x-152t). The wavelength is determined to be 1.50 meters, and the wave velocity is 32.3 m/s. To find the maximum speed in the y direction, participants confirm that the derivative of the wave function with respect to time should be taken, leading to dy/dt=0.044cos(4.20x-152t)(152). The maximum speed is achieved when the cosine function equals 1, resulting in a maximum speed of 6.688 m/s. The calculations and method for finding the maximum speed are validated by participants in the discussion.
Naldo6
maximum speed of a string...help please
A tranverse mechanical wave is traveling along a string lying along the x axis. The displacement of the string as function of position and time, y(x,t) is described by the following equiation:
y(x,t)=0.044 sin(4.20x-152t) where x and y are in meters and t is in secnds. Find the wavelength of the wave, the velocity of the wave and the maximum speed in the y direction of any piece of the string.
i have done yet the wavelength and the velocity but i don't know how to calculta the maximum speed in the y direction o any piece of the string.
wavelength= 1.50 meter
velocity of wave= 32.3 m/s
maximum speed= "I don't know"
can anyone help me please
Here are a few pointers:
1) Generally, v= ds/dt, so, what do you need to do with the wavefunction?
2) Where and when does a particle on a wave achieve maximum transverse (in the y direction) velocity ?
do yoy mean derivate the y equation?... and set x = o
Yes, precisely. There is a simpler method for the 2nd part, however. What is the maximum value of the trig function that you'll find in the derivative?
y=0.044 sin(4.20x-152t)
dy/dt= 0.044cos(4.20x-152t)(152)
and then set x=0
is this correct?...
not exactly right, what is the maximum value [cos (4.20x-152t)] can take? (Hint: cos(f(x)) has a finite range between ... and ...)
i really don't know because in the equation i have a t for time yet, so what i do with that variable?... or what i have to set in the derivate for get the maximum speed?...
well, the simple answer is that the maximum value of a cos function is always 1, regardless of the variable present within the function (assuming, of course, that their domains are for all real numbers). For max speed, the cos (4.20x-152t) simply equals 1.
oh yes i foget that in an instant so my
so the max speed is (0.044))(152)
is this now right?... do i derivate correctly?...
Yes, that should be right.
thanks... it is the correct answer
