How Does the Definition of Work Affect the First Law of Thermodynamics Equation?
The discussion centers on the interpretation of work in the context of the First Law of Thermodynamics, specifically the equations ΔU = Q + W and ΔU = Q - W. Participants emphasize the importance of understanding the direction of energy transfer and the definitions of work (W) in different textbooks. The consensus is that W represents "work done on the gas" in the equation ΔU = Q + W, which indicates an increase in internal energy when work is applied to the gas.
  • Understanding of the First Law of Thermodynamics
  • Familiarity with thermodynamic variables: internal energy (U), heat (Q), and work (W)
  • Knowledge of energy transfer concepts
  • Ability to interpret different textbook conventions in thermodynamics
  • Research the implications of work sign conventions in thermodynamics
  • Study the derivation and applications of the First Law of Thermodynamics
  • Explore examples of energy transfer in thermodynamic systems
  • Examine how different textbooks present thermodynamic equations
Students of physics, educators teaching thermodynamics, and professionals in engineering fields who require a solid understanding of energy transfer and thermodynamic principles.
Nick tringali
I picked choice A but the Answer is choice B. The book literally states that when work is done on the system work is negative. I get that when it’s Adiabatic the equation simplifies to U=-W making it U=-(-W). Is this like a trick question? Why would the book tell me that when work is done on the system work is negative then also ask a question and state it’s actually positive. Hope this question makes sense.
Delta U= Q-W
Hi @Nick tringali.
You have to be very careful when thinking about the direction of energy-transfer when work is done (on something by something else).
Your textbook link says "... W is the work done by the system" [my underlining].
But the question is about "the work done on the gas" [my underlining; and of course 'the gas' is 'the system' here].
Yes, one needs to be careful about the preposition and be careful about who does the work and on whom work is done. It doesn't help that the first law appears as ##\Delta U=Q+W## in some textbooks and as ##\Delta U=Q-W## in others. Both are correct depending on the definition of ##W## in the textbook. As usual, ##\Delta U## is the change in internal energy and ##Q## is the heat that enters the gas.
To Nick tringali: Can you tell in which equation ##W## stands for "work done on the gas" and why? If so, then you understand what is going on here.
kuruman said:
Yes, one needs to be careful about the preposition and be careful about who does the work and on whom work is done. It doesn't help that the first law appears as ##\Delta U=Q+W## in some textbooks and as ##\Delta U=Q-W## in others. Both are correct depending on the definition of ##W## in the textbook. As usual, ##\Delta## is the change in internal energy and ##Q## is the heat that enters the gas.
I would say that U= Q+W equation is where W stands for work done on the gas. When work is done on the gas it increases the internal energy so +W being work done on the gas would make sense . Right?
