MCQ about intensity of sound waves (formula manipulation)
The discussion revolves around the manipulation of formulas related to the intensity of sound waves, particularly focusing on the relationship between intensity, amplitude, and distance. Participants are exploring how these variables interact within the context of sound wave physics.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants are attempting to understand the proportional relationships between intensity, amplitude, and distance. There are discussions about the implications of the proportionality constants and the lack of numerical values for certain variables. Some participants question the necessity of calculating the constant of proportionality.
The discussion is active, with participants providing insights and alternative approaches to the problem. Some guidance has been offered regarding the relationships between the variables, and there is an exploration of how changes in amplitude affect intensity at different distances.
There is a noted absence of numerical values for certain variables, which is affecting the ability to fully resolve the problem. Participants are working within the constraints of the problem as presented, with some assumptions about the relationships between the variables being discussed.
Originaltitle
The equation that is already given + (maybe) I is proportional to A2f2.
I took the square root of 8, 8 being the Amplitude and I being proportional to the square of A. (I make the constant of proportionality 1). That's not the answer.
Originaltitle said:
[ IMG]http://i49.tinypic.com/jts37a.jpg[/PLAIN]
If [itex]\ \displaystyle I\propto\frac{1}{x^2}\,,\[/itex] then [itex]\ \displaystyle I=\frac{k}{x^2}\,,\[/itex] where k is the constant of proportionality.
This means that [itex]I\cdot x^2=k\,,\ \text{ a constant}\ .[/itex]
Added in Edit:
This is wrong. See correct response below.
Obviously, but we can't find k here because we don't have a numerical value for x OR I.
You don't need to calculate k.
At point P, we have I=k/r^2
Write a similar expression for the intensity at Q and compare it with the above expression.
You are given an amplitude, A, at point P.
Also, [itex]\ \displaystyle I\propto\frac{1}{x^2}\,,\[/itex] and [itex]\ \displaystyle I\propto{A^2}\ .\[/itex] This means that [itex]\ \displaystyle A\propto\frac{1}{x}\,,\[/itex] assuming they're both positive. Therefore, Ax = k, where k is some constant.
You don't need a numerical result for k.
Ax at P
is equal to
Ax at Q .
@ P, A = 8μm and x = r .
@ Q, x = 2r , what is A ?
A is inversely proportional to x. So if A is doubled, x will be two times less. So if A at x is 8, A at 2x will be 8/2 which is 4.
Thanks!
  • · Replies 19 ·
