Mean elongation of spring with temperature
5 replies · 3K views
jorgen
Hi all,
I have to determine the mean elongation of a spring with temperature. The spring constant is alpha and the gravitational acceleration is g. I have the following expression for the force
[tex]F = -\alpha*x +m*g[/tex]
which I can integrate for an expression of the energy
[tex]E = \frac{-\alpha*x^2}{2}+m*g*x[/tex]
I can factorize this into
[tex]E = (x-\frac{m*g}{\alpha})^2[/tex]
than I would like to put it into the Boltzmann distribution getting the partition function and from that determine the mean elongation
[tex]Z = \int_{-\infty}^{\infty}exp(-E*\beta)[/tex]
but this gives me infinity - any help or advice appreciated thanks in advance,
Best
J
jorgen said:
Hi all,
I don't think so. If you expand that expression, you get something different than
which you had before.
Also, the potential energy of the spring should be +½αx2
Also, are you defining a positive displacement as upward or downward?
Best
J
hi,
I am defining the displacement from -infinity to +infinity where the Boltzmann weights should be very small for none probable elongations.
The potential energy is
E = alpha*x^2/2 + m*g*x
I need some hints on how to factorize the energy. Thanks in advance
I think I see where you need to go with this.
Are you familiar with "completing the square" for quadratic expressions? That would be a good way to manipulate your energy expression, and get the integral in terms of something you can evaluate.
BTW, is your integral expression missing a "dx" term?
Hi again,
I write the potential energy as (x-m*g/alpha)^2 and then substract the constant which is just a constant so it is not so important - I guess? - then I write it as a Boltzmann
[tex]mean(x) = \frac{\int_{-\infty}^{\infty}x*exp(-\beta*(x-m*g/alpha)^2}{ \int_{-\infty}^{\infty}exp(-\beta*(x-m*g/alpha)^2)}[/tex]
which due to the symmetry gives zeros - does this seem reasonable and any hints how to proceed to find the variance?
Any hints appreciated thanks in advance
Best
J
jorgen said:
Hi again,
Ah, you're right, the constant is not important and would cancel out later anyway.
That being said, how would you feel about
(alpha/2) (x + m g / alpha)2
for the potential energy? If you're in doubt, try expanding that expression, also expand what you had, and compare them with
alpha x2/2 + mgx​
... - then I write it as a Boltzmann
Actually, the integral in the numerator is not zero.
I'd look at the definition of variance, and evaluate the integrals involved.
