Measuring AC current with an oscilloscope.
This discussion focuses on measuring AC current through an LED using an oscilloscope. The recommended method involves placing a resistor in series with the LED to measure the voltage across it, applying Ohm's Law for current calculation. For low currents in the nano to pico-ampere range and frequencies above 100 kHz, a current-to-voltage converter using an operational amplifier (Op-Amp) is suggested. Additionally, participants recommend exploring current sense amplifiers with programmable gain for enhanced reliability and performance.
  • Understanding of Ohm's Law and basic circuit theory
  • Familiarity with operational amplifier (Op-Amp) circuits
  • Knowledge of current sense amplifiers and their applications
  • Experience with oscilloscopes and AC signal measurement
  • Research "current voltage converter" circuits for low current applications
  • Explore "current sense amplifier" options with programmable gain
  • Study the principles of measuring AC signals with oscilloscopes
  • Investigate techniques for temperature and bias current compensation in circuits
Electronics engineers, researchers in low-power applications, and anyone involved in precise current measurement and analysis using oscilloscopes.
FM79
I have a technical question, for research purposes.
I have LED that we probe in AC mode. To measure the applied voltage in AC and the light-response in AC is no problem.
However I would like to measure the current going through the device as well and I would like to link it to an oscilloscope. Now OSC usually measure potential (and have limited range) and I'd like to know how to have a signal directly related to the current on the OSC.
If you know of any particular instrumentation please let me know.
Put a resistor in series with the LED and measure the voltage across it with a scope. That's how I've done it in the past. Ohms law rocks.
Yes, that's basically trivial.
I was looking for a more detailed and reliable solution. Currents will be in the range from nano to micro ampere (or even pico-ampere for some other devices) and frequencies above 100 kHz.
I think that, amplifier aside, I need a bit more than that.
By AC mode I assume you are using a time dependent driver for the LED. Why are the currents you expect so small?
Because I am working at low voltages and new materials.
The standard current-to-voltage converter for very low current is the classic Op-Amp circuit:
Depending on your requirements, the circuit can be tweaked to compensate for temperature and bias current variations. Google "current voltage converter".
Check for some 'current sense amplifier' with programmable gain. Pretty reliable stuff, and usually there is a ton of AppNote too.
Thank you Svein and Rive.
