Why isn't the scaling factor included when stating particle mass in eV?
The discussion centers on the relationship between energy and mass, specifically why particle mass is often stated in electron volts (eV) without including a scaling factor. It emphasizes that eV is a unit of energy, similar to joules, and that mass can be expressed in various units, including eV, joules, and kilograms. The conversion between these units is straightforward, as demonstrated through the equation E=mc^2. The key point is that when mass is given in eV, it is implicitly understood that the conversion to other units is possible without explicitly stating the scaling factor. Ultimately, eV/c² serves as a valid unit of mass, just as grams or kilograms do.
Jrs580
Silly question I know…but…the energy mass relationship is E=mc^2 with E in units of Joules. Which means mass = E/c^2 and if we take c = 1, mass = joules. So where did the conversion factor of e go when we state particle mass in eV?
E=mc^2
not technically a homework question, just figured it fit here.
What conversion factor? eV is a unit of energy just as Joule is.
Jrs580 said:
Homework Statement:: Silly question I know…but…the energy mass relationship is E=mc^2 with E in units of Joules.
This equation holds for any consistent system of units. E.g energy in joules, mass in kilograms and speed in metres per second.
Or, energy in electron volts and mass in electron volts over ##c^2##. For example, the mass of an electron is about ##0.5 MeV/c^2##.
In that case, you are free to choose any units for length and time. If you choose units where ##c =1## then the mass of an electron in those units is ##0.5 MeV##.
Ok let me try again, lol. E=mc^2 where m:kg and E:joules.
E/1.6e-19 = energy in eV = E’ = (mc^2)/1.6e-19
m = E’(1.6e-19)/c^2
So to get mass in kg you have to do the prescription above to the energy measured in eV. But when particle mass is stated, it doesn’t include this scaling factor.
I believe the major point is that you can quote mass in any of these units (eV, joules, kg) because you can always convert between them. They are all the same. Just as a week a month or a year can be used to describe a given amount of time.
m = E’(1.6e-19)/c^2
I'm not sure I follow this. The mass of the electron is ##9.1 \times 10^{-31}kg##. So, its rest energy is:
$$E = mc^2 = (9.1 \times 10^{-31}kg)\times(9 \times 10^{16} m^2/s^2) = 8.2 \times 10^{-14}J$$To convert from joules to ##eV## we have ##1J = 6.24 \times 10^{18} eV##, so:
$$E = (8.2 \times 10^{-14}J)\times (6.24 \times 10^{18} eV/J) = 0.51 MeV$$Finally, using ##E = mc^2## in ##eV##, we have:
$$m = E/c^2 = 0.51 MeV/c^2$$is the mass of the electron in ##eV##.
m = E’(1.6e-19)/c^2
Because mass doesn't have to be given in units of kg. Your question is kind of like asking: when a mass of a nickel is given as 5 grams, how come there's no factor of 0.001 thrown in (to convert it to kg)?
The unit ##{\rm eV}/c^2## is just another unit of mass, like a gram is.
Likes PeroK
  • · Replies 18 ·
