Measuring the length of a moving Beam in two different directions
The discussion revolves around measuring the length of a moving beam from the perspective of a walker on the ground, who observes the beam passing in two different directions. The problem involves understanding the relationship between the speeds of the walker and the beam, as well as the time taken to pass the beam in each direction.
  • Participants explore the implications of measuring the beam's length while walking in the same and opposite directions. They discuss the relationship between the times taken to pass the beam and the speeds involved, questioning how to express these relationships mathematically.
There is active engagement with various interpretations of the problem, including the significance of the time measurements and the relationship between the speeds of the walker and the beam. Some participants have suggested potential equations and relationships, while others express uncertainty about how to proceed further.
Participants mention the assumption that the walker moves at a constant speed and that the measurements are based on the time taken to walk a certain number of steps. There is also a discussion about the implications of these assumptions on the calculations involved.
  • #31
kimiko333 said:
:O Where?
How do you get ##L = 3##?
  • #32
kimiko333 said:
:O Where?
The length of the beam cannot be less than both 10 and 15 steps.
  • #33
If I substitute 10 into the first equation, I get:
##L=t_1*(\frac {v} {5} +v)##
##L=2v+v=3v##
  • Skeptical
  • #34
##L=2v+v=3v##
I'm not impressed by that!
  • #35
:biggrin: but why is this so? I'm supposed to get 12. And I get 12 with the second equation
  • #36
It's just totally wrong! You multiply something bigger that ##v## by ##10## and get ##3v##? Come on!
  • #37
Oh Jesus. I forgot to multiply v by 10. Aaaahhhh. Told you... I'm tired :D
  • #38
Now it's 12, okay. But if I substitute in, I get 12v, not just simply 12. How do I know, that the answer is in steps?
  • #39
That's the units you used when you set ##t_1 = 10##. That's time in units of "time for a step". In those units ##v = 1## (meaning ##1## step per time for a step).
When you come to study Special Relativity, you'll find this is an amusing analogy to setting the speed of light ##c = 1##!
Alternatively, you could have left time in unspecified units, whereby:
##L = \frac{6}{5}vt_1##
And ##vt_1 = 10## steps.
  • #40
Ooooh, okay. Totally makes sense! Great! Thank you! :D Now I just have to figure out, why is it that I can easily solve problems in electrodynamics, thermodynamics, etc, but don't know how to deal with these... :D (I'm a teacher-student, studying to be an English and Physics teacher)
  • #41
You started off with the assumption that the quantities could be determined. But, actually, the only things that could be determined were the relationships between quantities. You end up with 12 steps, but that's true whatever the speed of the walker and beam. All we've found is that one is 5 times the other - but, they could be anything.
This is the sort of problem that undermines the "plug-and-chug" approach - too many unknowns, you said. Well, everything is still an unknown, because we don't know how long a step is or how fast anything is moving.
Finally, there is a difference between a problem being elementary and being difficult. This is an elementary problem that really made you think. You might have an advanced EM problem that involves advanced concepts but only requires you to plug the given numbers into the correct formula - so it's advanced but easy.
  • #42
Great answers! Thank you for the explanations! :) I'm grateful!
  • #43
PS if the walker takes ##s_1## steps walking in the same direction as the beam is moving; and, ##s_2## steps walking in the opposite direction; then, the length of the beam in steps is $$\frac{2s_1s_2}{s_1 + s_2}$$
We can check that for ##s_1 = 15## and ##s_2 = 10##, we do indeed get the answer of ##12## steps.
In general, I'm rarely content to solve a single numerical problem. I usually want to find a general formula like the one above.
  • #44
I know it’s a bit late, but I think there are 2 possible solutions depending on which is faster, the walker or the wagon. The original question seems to allow both possibilities.
Take the unit of distance as 1-step and the unit of time as the time-for-1-step.
Speed of walker = 1.
Speed of wagon = v.
There are 2 cases:
Case 1; wagon is faster than walker: v>1
Case 2: wagon is slower than walker: v<1
___________________________
When walker and beam move in the same direction:
Front of beam passes observer at ##t=0##
Back of beam passes observer at ##t= t_1##
##t_1 = \frac {L}{v-1}## (since speed of walker relative to beam is v-1.)
When walker and beam move in opposite directions:
##t_2 = \frac {L}{v+1}## (since speed of walker relative to beam is v+1.)
Eliminating v gives:
##L = \frac {2t_1t_2}{t_1 – t_2}##
Since the number of steps is the same as the number of time units:
##L = \frac{2s_1s_2}{s_1 – s_2}##
For ##s_1 = 15## and ##s_2 = 10##
##L = \frac {2·15·10}{15 – 10} = 60##
____________________________________
Observer passes back of beam at ##t = 0##
Observer passes front of beam at ##t = t_1##
##t_1 = \frac {L}{1-v}## (since speed of walker relative to beam is 1-v.)
When walker and beam move in the opposite directions:
##L = \frac {2t_1t_2}{t_1 + t_2}##
##L = \frac{2s_1s_2}{s_1 + s_2}##
##L = \frac {2·15·10}{15 + 10} = 12##
  • #45
Good thinking outside the proverbial box. The statement of the problem invokes the stereotypical picture of a fast walker catching up with a slow-moving (ox)cart. It would have been different if the beam were on a flatbed truck on the highway. Either formulation would have two solutions.
  • · Replies 44 ·
