Measuring the magnetic and electric constants
The permeability (μ₀) and permittivity (ε₀) of free space are defined constants in the SI system, with μ₀ = 4π x 10-7 Henrys/m and ε₀ = 8.85 x 10-12 Farads/m, derived from the speed of light (c). These constants cannot be independently measured in a vacuum due to their dependence on other defined quantities, such as the meter and the speed of light. The 2002 table of fundamental constants lists both as exact values, indicating no uncertainty. While dimensionless constants can be measured directly, the vacuum constants serve to interrelate various physical equations within the SI system.
  • Understanding of SI units and their definitions
  • Familiarity with electromagnetic theory
  • Knowledge of fundamental physical constants
  • Basic grasp of measurement techniques in physics
  • Research the derivation of the speed of light and its implications on physical constants
  • Explore the role of fundamental constants in the SI system
  • Investigate measurement techniques for dimensionless quantities in physics
  • Study the differences between SI and CGS systems in electromagnetism
Physicists, electrical engineers, and students of physics seeking to understand the implications of fundamental constants in theoretical and applied contexts.
nuby
Has the permeability and permittivity of vacuum ever been measured in a vacuum or space?
The permeability of free space is defined as u0 = 4 pi x 10-7 Henrys per meter in the mks system of units. Because the speed of light is a defined quantity, and 1/sqrt(u0 e0) = c = speed of light, e0 is then derived as 8.85 x 10-12 Farads per meter. So the measurement of the permittiviy depends on the the speed of light, which is now an exact defined quantity, because the meter is based on the speed of light: The meter is the distance light travels in 1/299792458 seconds.
So it isn't measurable? You can't go into outer space, and measure the permeability and permitivitty of vacuum..
The permeability and permittivity of free space are now defined by other quantities, such as the length of a meter and the speed of light. Suppose you measured the capacitance of two one-square-meter plates separated by 1 millimeter in vacuum. Because the meter is defined by c, and c = 1/sqrt(u0e0), the measurement is not an independent measurement. the value of all the fundamental constants are based on a variety of interdependent quantities, every value is over determined, and least square fits are used to get the most probable values. In the 2002 table of the fundamental constants (which I am now looking at), both the permeability and permittivity of free space are "exact" defined quantities, meaning no uncertainty in value.
So you cannot go out into intergallactic space and measure them, because of their dependence on other quantities. On the other hand, dimensionless quantities, like alpha, are dimensionless and measurable.
Added detail- Look at the Particle Data Group page
http://pdg.lbl.gov/2008/reviews/contents_sports.html
Click ion the first catergory (constants), then look at about lines 13 and 14 for permeability and permittivity of free space. They are shown as EXACT quantities, because they are based on a) definition of the permeability of free space and b) the speed of light.
Why do you need to go into outer space to measure a quantity in a vacuum? Got a bell jar?
So is all the above correct? Vacuum constants can't be measured? I know they're derived from the speed of light... But wouldn't saying "the vacuum constants can't be measured" be similar to saying "the speed of light can't be measured"? And if the constants have no physical significance, why are they used in so many useful equations? I'm lost
No, because you can measure the speed of light directly without involving these constants, in the simplest case just by measuring the time it takes for a signal to travel between point A an B.
Of course there are more sophisticated ways of doing it, but the point is that back when they were doing this (before the speed of light was defined to be constant, nowadays they instead measure the length of the meter) they used methods where the result only depended on a time and a length (and therefore indirecly on the definition of the meter, which back then was defined using an artifact).
Constants like these are used to "glue" the SI system together. Some constants are always needed in a system and choice of which ones to include is to some extent arbitrary. In e.g the CGS system the permeability of vacuum is a dimensionless number equal to one. Hence, in equations where the CGS systems is used (nowadys mainly in the area of magnetism) there are fewer constants when dealing with magnetism (the fact that the equations are different depending on the system used can be quite confusing)
  • · Replies 16 ·
  • · Replies 41 ·
  • · Replies 21 ·
