Measuring time constant using an inductor with a core vs. no core
The discussion revolves around measuring the time constant in RL circuits using coils with and without a magnetic core. Participants explore the effects of core materials on inductance and time constants, addressing experimental discrepancies and potential solutions.
  • Experimental/applied
  • Some participants note that experimental results with air core coils align well with predictions, while results with steel or iron cores deviate significantly.
  • One participant suggests that large eddy current losses in the core may be responsible for the discrepancies observed with the core inserted.
  • Another participant inquires about the time constant with the core inserted and suggests calculating the inductance based on that measurement.
  • Some propose using a ferrite rod instead of a steel core to mitigate eddy current issues.
  • There is a discussion about the geometry of the core and the potential impact of air gaps on inductance measurements.
  • One participant shares their experience with transformers wound on a steel bolt, indicating they did not function as expected.
  • Concerns are raised about the stability of inductance due to possible air gaps and misalignment in the core structure.
  • Participants discuss the measurement setup, including the use of an LCR meter and the importance of frequency in inductance measurements when a magnetic core is involved.
  • One participant expresses uncertainty about the suggestion to create an air gap and seeks clarification on its purpose and implementation.
Participants do not reach a consensus; multiple competing views and uncertainties remain regarding the effects of core materials on inductance and time constants, as well as the best approaches for measurement and experimentation.
Limitations include potential variations in inductance due to core geometry, air gaps, and the frequency of measurements impacting results. The discussion reflects a range of experimental conditions and assumptions that may influence outcomes.
This discussion may be useful for students and educators involved in experimental physics, particularly those working with RL circuits and inductance measurements in laboratory settings.
Taulant Sholla
I'm doing a simple RL Circuit Lab where students use 800- and 1600-turn air core coils to measure the time constant. Experimental results very nicely agree with predicted results.
However, when students insert a steel (or iron) core in the coils, experimental results are far different than predictions.
Any ideas are appreciated!
The inductance of your air coils is maybe in the millihenry range, and I am guessing you may be using short time constants of a fraction of a second. These short time constants involve rapid rate-of-change of flux, which might create large eddy current losses in the core.
Yes, inductance ranges from 10-40 mH, with time constants in the realm of 0.6-0.8 milliseconds. I had no idea these losses are so substantial!
Thank you.
What time constant do you get with the core inserted?
From that, compute the value of coil inductance when the core is inserted.
Maybe inserting a ferrite rod would give a result for the pupils and would not involve eddy current problems.
I think the question is whether the increase if inductance due to a core, would slow the response to the point where there is enough core to handle the flux.
What type of core are you using? What is the geometry?
If it is a gapless structure, then you may see large variations in the inductance because of the unintended introduction of an air gap due to misalignment, surface roughness, or contamination. A tiny air gap can have a really large effect. If this is the case, I would suggest including an intentional air gap, like some paper or plastic. With a gapped structure and a high permeability material, the inductance is mostly affected by the air gap and less sensitive to the permeability of the core. There is a really significant difference between a 1mm ± 0.1mm gap and a 0.1mm ± 0.1mm gap.
I have tried making simple transformers wound on a steel bolt and they do not work at all!
Thank you for your very thoughtful reply!
I've included an image of the coil and core we use below. For our RL lab, we simply use one coil, not the two as shown. Using a single 800-turn coil with the pictured closed loop core increases the inductance from about 10mH to 70mH. Not exactly sure what you're suggesting--basically shimming remaining air gaps with additional high permeability material?? Again, our results with no core whatsoever are great; with a core, whether a single bar (removed from the loop), or the entire closed loop--not even close.
I was thinking a greater time constant might yield better results between experiment and prediction. We do indeed get good results now using 800- and 1600-turn air core coils. Using any kind of core (laminated closed loop square core or laminated single-bar core) yields very inaccurate results. So for now I just skip using cores, but it would be great if students used the core, measured the much greater inductance, and still got good agreement between experiment and prediction. This is not the case.
This is a possibility, but right now students use an LCR meter to measure inductance and resistance, and use this as the basis for comparing experimental results to predictions. I like having them get hands-on experience with LCR meters and others devices as mush as possible.
No, make an air gap between the core halves (assuming there was none originally); a part of the path the magnetic flux must travel that doesn't go through the high permeability core material. This makes the total permeability of the structure more stable. You will, of course, get less inductance than with no gap, but it will be harder to saturate the core and the assembly will be less sensitive to "accidental" air gaps. The material you put in the gap between the core haves can be anything non-magnetic, like post-it notes for example.
http://info.ee.surrey.ac.uk/Workshop/advice/coils/gap/index.html
How are they measuring the time constant? What is your excitation and how do you observe the decay?
I'll try this - thank you. Learning a lot here.
They use an integrated lab management setup from PASCO. A single interface box provides signal generator output and inputs for various sensors. We can adjust several AC parameters, and can also specify sample rates for voltage and current sensors. We gather a graph like this (except we collect voltage rather than current data). This experimental results is compared to tau=L/R where L and R are measured using an LCR meter.
Once a magnetic core becomes involved there are frequency effects and magnetic energy storage non-linearities such as hysteresis. That may make RL unipolar current experiments confusing.
The frequency of measurement used by the LCR meter will become more important in the presence of a magnetic core. What frequency is used for the inductance measurements? What is the make and model of the LCR meter?
OK, so you are looking at the voltage step response of an L-R low pass filter?
Thanks for your continued help! I'm traveling and have limited connectivity opportunities, hence the gaps between my responses. Here's the LCR meter we use:
"Proster LCR Meter Capacitance Inductance Resistance Tester Multimeter Self-discharge with Overrange Display"
https://nanopdf.com/downloadFile/operation-manual-of-digital-lcr-meter-1general-this_pdf
Yes, students measure the experimental time constant and compare to the predicted value (based on LCR values given by an LCR meter) for a series of RL combinations based on 800- and 1600-turn coils and 5-,10- and 22-ohm resistors.
  • · Replies 29 ·
  • · Replies 16 ·
  • · Replies 43 ·
  • · Replies 35 ·
20K
