Mechanical Energy Lost In A One-dimensional Collision
The discussion focuses on a one-dimensional collision involving a 1200-kg car and a 9000-kg truck, where the car's initial speed is 25 m/s and the truck's is 20 m/s. After the collision, the car's speed is 18 m/s, leading to the calculation of the truck's final velocity as 20.9 m/s. The mechanical energy lost in the collision is calculated to be approximately -14,955 Joules, while the book states the answer is 8.74 kJ, indicating a discrepancy likely due to rounding errors in calculations. The energy loss is attributed to thermal energy, physical deformation, and frictional dissipation.
  • Understanding of conservation of momentum in collisions
  • Knowledge of kinetic energy calculations
  • Familiarity with the concepts of mechanical energy and energy loss
  • Basic algebra for solving equations
  • Review the principles of conservation of momentum in elastic and inelastic collisions
  • Learn about energy transformation during collisions and how to account for energy loss
  • Study the effects of rounding in calculations and its impact on results
  • Explore real-world applications of collision physics in automotive safety
Students studying physics, particularly those focusing on mechanics and collision theory, as well as educators seeking to clarify concepts of energy loss in collisions.
NoPhysicsGenius
A 1200-kg car traveling initially with a speed of 25 m/s in an easterly direction crashes into the rear end of a 9000-kg truck moving in the same direction at 20 m/s. The velocity of the car right after the collision is 18 m/s to the east. (a) What is the velocity of the truck right after the collision? (b) How much mechanical energy is lost in the collision? How do you account for this loss in energy?
m_1v_{1i} + m_2v_{2i} = m_1v_{1f} + m_2v_{2f}
K = \frac{1}{2}mv^2
I was able to solve part (a) as follows ...
\Rightarrow v_{2f} = \frac{m_1v_{1i} + m_2v_{2i} - m_1v_{1f}}{m_2}
\Rightarrow v_{2f} = \frac{(1200 kg)(25 m/s) + (9000 kg)(20 m/s) - (1200 kg)(18 m/s)}{9000 kg} = 20.9 m/s east
For part (b), however, I didn't get very far ...
I know the energy loss is due to heat (thermal energy), but I could only calculate the loss in kinetic energy, not mechanical energy:
K_f - K_i = \frac{1}{2}m_1{v_{1f}}^2 + \frac{1}{2}m_2{v_{2f}}^2 - \frac{1}{2}m_1{v_{1i}}^2 - \frac{1}{2}m_2{v_{2i}}^2
\Rightarrow K_f - K_i = \frac{1}{2}(1200 kg)(18 m/s)^2 + \frac{1}{2}(9000 kg)(20.9 m/s)^2 - \frac{1}{2}(1200 kg)(25 m/s)^2 - \frac{1}{2}(9000 kg)(20 m/s)^2 = -14,955 Joules = -15.0 kJ
The problem is that the answer in the back of the book is 8.74 kJ.
Check your calculation again: working with your numbers, I don't quite get the book's result, but it's close (-9310 J). (Be careful about how much you round-off by early in the calculation. I may not be getting the book's answer because I used 20.93 m/sec for the truck's later speed, rather than 20.9.)
As for where the energy went, the term "internal energy" is a catch-all for lots of processes. Some of the energy could well go into heating, but some could also go into "physical deformation" of the bodies of the car and truck (crash damage), into frictional dissipation with the road surface because the rolling of tires briefly became sliding, and (a rather tiny bit) into sound (acoustical) energy.
I can't see anything wrong with your calculation. Mechanical energy is kinetic energy that isn't thermal energy.
i get -8680 no rounding
