Mechanical Engineer Class Interview
A sophomore is seeking to conduct an interview with a mechanical engineer to gain insights into the field. The request emphasizes urgency for a response. Participants in the discussion inquire about the specific area of mechanical engineering the student is interested in, such as petroleum, defense, or aerospace. This clarification could help connect the student with a relevant professional. Engaging with an engineer in the desired field can provide valuable career guidance.
Kevin.Reid414
Hello, I am a sophomore and I need to conduct an interview on an engineer in the field i
wish to enter into one day, so i was looking for a mechanical engineer, so if someone could get back to me as soon as possible that would be great, thanks for your time,
Kevin.Reid414
Kevin.Reid414
what field? petro? defense? aero?
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
