Mechanical mass-spring-damper model from IV curve
7 replies · 7K views · last reply
abburiaditya
hey guys, I have an IV cure from which i need to develop a mass-spring damper model... can somebody help me with that.
the curve has basically a 3 slopee, each linear...
if somebody has any kinda idea abt this, i can post the curve as an image...
thanks
I'm not real clear yet on what you are trying to do, but yes, any figures or more info that you can post will help.
i have posted a curve that i have obtained from tests on a bunch of nanowires... i need to develop a spring-mass-damper system that best describes this curve...
the mechanical analogy for current i guess is Force and for voltage is Velocity, so this same curve is again a force vs velocity curve... so is it possbile to get a spring-mass-damper system from the curve?
I'm still not clear on the mechanical analogy thing, but before that, why is that plot not linear? How was that data gathered?
i guess the plot is not completely linear because this is how the nanowires behave... the data was gathered using a Keithley 4200, which is a semiconductor characterization system and a probe station
Fair enough. Why do you need to translate that into a spring paradim, or am I misinterpreting your question?
this is basically part of my research... nobody has researched the materials i have been working on... so now that we have some data and plots, we want to get an electrical model and also into a spring paradime... we want to investigate certain efeects that might be going on in the wires... like maybe a peizo electric effect... so that is why i need to develop those models
The intristic parameter you can recover from IV curve is R (resistance), which is simply V/I
The instristic parameter of a spring is of course the spring constant k.
Hooke's law is F = -k*x
so k = -F/x
Now you can substitute Volts (V) for Force (F) and current (I) for displacement (x)
That would model a non-linear spring, possible made from some weird alloys, because your data is non-linear.
BTW, this is one of many possible transformations. Whatever you do, you have to preserve R.
