Mechanics question (beginner level)
  • Thread starter Thread starter trew
    Mechanics
The discussion revolves around resolving forces in a mechanics problem, specifically focusing on the decomposition of a 25N force into its components relative to an incline. Participants are exploring the relationships between angles and components in the context of vector resolution.
  • Participants are attempting to resolve the 25N force into components, questioning the correct angles and relationships involved. There is discussion about the use of trigonometric functions and the formation of right triangles to visualize the problem.
The discussion is ongoing, with participants expressing confusion about the correct setup for resolving the force. Some have provided diagrams and examples to aid understanding, while others continue to seek clarification on the relationships between the components and the angles involved.
There is mention of a video that may provide additional context, and participants are reflecting on their preferred methods for visualizing and calculating force components, indicating a variety of approaches and levels of understanding.
trew
Find acceleration of the box
coefficient of friction and
I'm okay with the concept of resolving into two components.
BUT, with re: to resolving perpendicular to the acceleration, I don't understand how 25cos80 comes into?
Surely it should be included when I'm resolving in the direction of the acceleration?
Don't forget that cos(80) = sin(10). Sine and cosine are co-functions.
The component of the 25N in the direction of acceleration would be 25 cos(10). This is the other component.
Thanks for your help so far but tbh I'm still lost.
Here's what I've done so far:
So I've resolved the first part into 2gsin10 and 2gcos10 but after looking at the problem for the past hour I still can't see how I can break down the 25N into two components.
Draw a similar triangle for that 25N force. The force acts horizontally: you want its components perpendicular and parallel to the incline. What angle does the force make with the incline?
Ok so I did that and this is what I got:
so I can't see how I would still get 25cos10 for the hypotenuse side? Or have I done this triangle wrong?
Yes, the triangle is wrong. The 25N force must be the hypotenuse of the right triangle. (The components will be the shorter sides.)
Ok I'm back a day later and I still don't get it o_O
I looked at this video:
which has pretty much the same question and I still can't visualise the triangle with the 25N force being the hypotenuse.
I've tried many combinations but I can't form a triangle with the 25N and it's two components.
Also, I like using sin0=opp/hyp and cos0=adj/hyp to work out these forces but since I can't see how that triangle is formed I can't use this method.
For me it's the best method since I can learn what's going intuitively as opposed to assuming that cos is associated with the x-direction and sin with the y-direction.
Nothing wrong with using a right triangle to find the components. Here's a diagram for a similar problem (that I found on the web). Perhaps it might inspire you:
240982
In that diagram, the applied force Fa is horizontal just like in your problem. (See if you can find the correct right triangle.)
Good! Never do things blindly as you can easily make a mistake.
Nonetheless, as long as the angle Θ is with respect to some axis (whatever that is in your problem), then FcosΘ will be the component parallel to that axis.
Can you find the x and y components of the 25 N force?
