Mechanics question with parachute
The discussion focuses on the mechanics of a parachutist's fall, specifically analyzing the forces acting on the parachutist before and after the parachute opens. The parachutist falls freely under gravity until the parachute opens, at which point an upward resistance proportional to velocity (kv) is introduced. The total distance fallen when the velocity reaches \(\frac{3mg}{4k}\) is established as \(\frac{m^2 g}{8 k^2} (8 \ln 2 - 1)\). Participants also identify a critical error in the calculations regarding the dimensions of the constant k, emphasizing the importance of dimensional analysis in physics.
  • Understanding of Newton's laws of motion
  • Familiarity with differential equations
  • Knowledge of dimensional analysis
  • Basic principles of kinematics
  • Study the derivation of motion equations under variable acceleration
  • Learn about the application of dimensional analysis in physics problems
  • Explore the effects of drag forces on falling objects
  • Investigate the mathematical modeling of parachute dynamics
Physics students, mechanical engineers, and anyone interested in the dynamics of falling objects and the effects of air resistance.
Sink41
1. A parachutist of mass m falls freely until his parachute opens. When it is open he experiences an upward resistance kv where v is his speed and k is a positive constant.
The parachutist falls from rest freely under gravity for a time \frac{m}{2k} and then opens his parachute. Prove that the total distance he has fallen when his velocity is \frac{3mg}{4k} is \frac{m^2 g}{8 k^2} (8 \ln2 - 1)
2.
a = v \frac{dv}{ds}
v^2 = u^2 + 2 a s
v = u + a t
3. Until parachute is opened:
t = \frac{m}{2k}
a = g
u = 0v = u + a t
v = \frac{mg}{2k}v^2 = u^2 + 2 a s
\frac{m^2 g^2}{4 k^2} = 2 g s
\frac{m^2 g}{8 k^2} = s
When parachute is opened:
Force downwards ma = mg - kv
m v \frac{dv}{ds} = mg - kv
\int \frac{mv}{mg - kv} dv = \int dsSubstitution: u = mg - kv
\frac{du}{dv} = -k
v = \frac{u - mg}{-k}\int \frac{mv}{-k (mg - kv)} du = \int ds
\int \frac{m(u - mg)}{u} du = \int ds
\int m - \frac{m^2 g}{u} du = \int ds
mu - m^2 g \ln u = \int ds
m (mg - kv) - m^2 g \ln (mg - kv) = s + c where c is a constant
To work out constant:
v = \frac{mg}{2k}
s = \frac{m^2 g}{8 k^2}m^2 g - mk \frac{mg}{2k} - m^2 g \ln ( mg - \frac{kmg}{2k} ) = \frac{m^2 g}{8 k^2} + c
\frac{m^2 g}{2} - m^2 g \ln ( \frac{mg}{2} ) - \frac{m^2 g}{8 k^2} = c
Putting c back into equation:
m^2 g - mkv - m^2 g \ln ( mg - kv ) - \frac{m^2 g}{2} + m^2 g \ln ( \frac{mg}{2} ) + \frac{m^2 g}{8 k^2} = s
Putting in value of v:
- \frac{m^2 g}{4} + m^2 g \ln 2 + \frac{m^2 g}{8 k^2} = s
\frac{m^2 g}{8} ( 8 \ln 2 - 2 + \frac{1}{k^2} ) = sSo i have wrong answer where have i gone wrong?
\frac{du}{dv} = -k
\int \frac{m(u - mg)}{k^2u} du = \int ds
Your error is shown above in the last line. You canceled the (-k) on the bottom instead of getting (-k)² (on the bottom)
u have given time is m/2k and k is a constant(dimensionless)...so how come time have dimensions "kg" (m->kg)...so check ur qstn..
k is a constant but it cerainly isn't dimensionless.
We are told: Restance = kv
and [R] = N
Since k = R/v, then
[k] = [N/(m/s)]=[Ns/m] - the dimensions of k.
Then [m/2k] = [kg/(Ns/m)] = [kgm/Ns] = - the dimension of time.
  • · Replies 21 ·
  • · Replies 27 ·
