Mechanics question with parachute
3 replies · 5K views · last reply
Sink41
1. A parachutist of mass m falls freely until his parachute opens. When it is open he experiences an upward resistance kv where v is his speed and k is a positive constant.
The parachutist falls from rest freely under gravity for a time [itex]\frac{m}{2k}[/itex] and then opens his parachute. Prove that the total distance he has fallen when his velocity is [itex]\frac{3mg}{4k}[/itex] is [itex]\frac{m^2 g}{8 k^2} (8 \ln2 - 1)[/itex]
2.
[tex]a = v \frac{dv}{ds}[/tex]
[tex]v^2 = u^2 + 2 a s[/tex]
[tex]v = u + a t[/tex]
3. Until parachute is opened:
[tex]t = \frac{m}{2k}[/tex]
[tex]a = g[/tex]
[tex]u = 0[/tex][tex]v = u + a t[/tex]
[tex]v = \frac{mg}{2k}[/tex][tex]v^2 = u^2 + 2 a s[/tex]
[tex]\frac{m^2 g^2}{4 k^2} = 2 g s[/tex]
[tex]\frac{m^2 g}{8 k^2} = s[/tex]
When parachute is opened:
Force downwards [itex]ma = mg - kv[/itex]
[tex]m v \frac{dv}{ds} = mg - kv[/tex]
[tex]\int \frac{mv}{mg - kv} dv = \int ds[/tex]Substitution: [tex]u = mg - kv[/tex]
[tex]\frac{du}{dv} = -k[/tex]
[tex]v = \frac{u - mg}{-k}[/tex][tex]\int \frac{mv}{-k (mg - kv)} du = \int ds[/tex]
[tex]\int \frac{m(u - mg)}{u} du = \int ds[/tex]
[tex]\int m - \frac{m^2 g}{u} du = \int ds[/tex]
[tex]mu - m^2 g \ln u = \int ds[/tex]
[tex]m (mg - kv) - m^2 g \ln (mg - kv) = s + c[/tex] where c is a constant
To work out constant:
[tex]s = \frac{m^2 g}{8 k^2}[/tex][tex]m^2 g - mk \frac{mg}{2k} - m^2 g \ln ( mg - \frac{kmg}{2k} ) = \frac{m^2 g}{8 k^2} + c[/tex]
[tex]\frac{m^2 g}{2} - m^2 g \ln ( \frac{mg}{2} ) - \frac{m^2 g}{8 k^2} = c[/tex]
Putting c back into equation:
[tex]m^2 g - mkv - m^2 g \ln ( mg - kv ) - \frac{m^2 g}{2} + m^2 g \ln ( \frac{mg}{2} ) + \frac{m^2 g}{8 k^2} = s[/tex]
Putting in value of v:
[tex]- \frac{m^2 g}{4} + m^2 g \ln 2 + \frac{m^2 g}{8 k^2} = s[/tex]
[tex]\frac{m^2 g}{8} ( 8 \ln 2 - 2 + \frac{1}{k^2} ) = s[/tex]So i have wrong answer where have i gone wrong?
[tex]\int \frac{m(u - mg)}{k^2u} du = \int ds[/tex]
Your error is shown above in the last line. You canceled the (-k) on the bottom instead of getting (-k)² (on the bottom)
u have given time is m/2k and k is a constant(dimensionless)...so how come time have dimensions "kg" (m->kg)...so check ur qstn..
k is a constant but it cerainly isn't dimensionless.
We are told: Restance = kv
and [R] = N
Since k = R/v, then
[k] = [N/(m/s)]=[Ns/m] - the dimensions of k.
Then [m/2k] = [kg/(Ns/m)] = [kgm/Ns] = - the dimension of time.
