Parachutist freefalling question
  • Thread starter sid9221
sid9221
http://dl.dropbox.com/u/33103477/parachutist.png
(This is from a mathematics not physics exam)
Well what I've done, is to compose the equation describing the velocity of the parachute once it has opened. I did this by setting up the differential equation as:
[tex]\frac{dv}{dt} = g-kv[/tex]
I solved that to get:
[tex]v = \frac{g}{k} - \frac{Ce^{-kt}}{k}[/tex]
Now the parachutist was traveling at v_0 when it deployed so I can say V(0)=v_0
hence solving I got:
[tex]v(t)= \frac{g}{k} - \frac{g-v_0k}{k}e^{-kt}[/tex]
Now the point is If I know how far from the ground the parachute opened I can figure out the distance traveled since the parachute was opened ?
I'm confused so any direction on how I should get to x(t) from v(t) would be useful.
The distance traveled is the integral of v(t). (V, the velocity, is the derivative of the displacement v=dx/dt. The parachutist travels vertically downward, so the displacement is the same as the distance traveled here.)
You made a small error in the first equation: dv/dt=-(k/m)v.
ehild
