Mellin Transforms -What could I be doing wrong?
  • Thread starter Thread starter ~Death~
The discussion revolves around computing the integral of x^(1/4)/(x^2+9)dx from 0 to infinity using Mellin transforms. The initial approach involves a complex formula that includes phase factors, but the user encounters discrepancies with the expected answer. Feedback highlights mistakes in handling phase factors and the use of the sin(5 pi/4) term, suggesting that the choice of polar angle conventions affects the results. Further guidance emphasizes the importance of clearly writing out the contour and residues without shortcuts to identify errors. The user is encouraged to provide detailed calculations to resolve the issue.
~Death~
I need to compute integral x^(1/4)/(x^2+9)dx from 0 to infinity
so I use a formula
-pie^(-5pi/4i)/sin(5pi4)SUM residues z^(5/4-1)/(z^2+9) so that's sqrt2pie^(-5pi/4i)3^(1/4)/(6i)(e^(pi/8i)-e^(3pi/8i)) (with the 0<arg<2pi branch of sqrt) but e^(-7pi/4)(e^(pi/8i))-e^(3pi/8i)) which is some horrible number...and that's not the answer according to my book
Looks like you made a mistake with the phase factors. It is not wise to put in the sin(5 pi/4) factor in there in the way you did.
You choose a convention for the polar angles and that chaoice then determines both the phase factors of the residues and the two phase factors of the two integrals along the real axis. The sum of the latter two phase factors will be proportional to a sinus term up to some phase factor.
i tried what you said
but i sitill can't seem to find where i went wrong
the formula in the text says -pie^(-pia)/sin(pia) SUM residues of fz^(a-1) excluding 0
= Integral -inf to inf z^(a-1)f(z)
Just write down the contour, and precisely write down the the residues and the contribution from the two integrals along the real axis, without talking any shortcuts. If you do that, then I can see where you go wrong if you don't get the right answer.
Relativistic Momentum, Mass, and Energy Momentum and mass (...), the classic equations for conserving momentum and energy are not adequate for the analysis of high-speed collisions. (...) The momentum of a particle moving with velocity ##v## is given by $$p=\cfrac{mv}{\sqrt{1-(v^2/c^2)}}\qquad{R-10}$$ ENERGY In relativistic mechanics, as in classic mechanics, the net force on a particle is equal to the time rate of change of the momentum of the particle. Considering one-dimensional...
  • · Replies 31 ·
