curto
- 19
- 0
use clausius-clapeyron equation: \frac{dp}{dt} = \frac{L}{T(V_{2}-V_{1})}
which can be rearranged (i think) in the following: p = p_{0}+\frac{L}{\Delta V}ln(\frac{T}{T_{0}})
so using the above equation i solved for T in which i got: T = T_{0}e^\frac{(P-P_{0})\Delta V}{L}
and then since density is equal to mass per unit volume i solved for V and got my two volumes by dividing the densities given by 11340. also 1 atm is roughly 10^6 pa so i used that and got a massive answer for T which is obviously wrong. then i just tried doing it in terms of atm in which i got a very small increase in temperature. isn't the melting point meant to become lower if the pressure is increased?? so how can T_{0} times e^{whatever} equal a number less than T_{0}?? does that mean my formula is wrong?
